I recently bought a COLORDUINO, and I find it very nice.
A link would be good so we can see what you are on about.
The constant current drive would be the way to go, you will ned one chip per LED, how many have you got? the darlingtons will not help you here.
Are you dealing with a multiplexed array? If so then it is tricky to increase the drive without pulling it all appart.
How is this for you? I only get a PDF file with squares and lines on it. No part numbers, no pin numbers, no IC signal names. It could be the schematic for anything. I am running a Mac so it might be an odd sort of Widows PDF.
as there is no common ground, but both ground and positive are switched on and off by the controller
Maybe something with NPN transistor on the 8 Vcc pin(LED's common anode), and PNP transistor for the 24 RGB pin?
It is not as simple as that because you need something to limit the current through the LED. A resistor will not cut it for a 1W LED because the forward voltage drop of these is not stable. Therefore you need something like a constant current supply to limit the current as well as hefty drivers. FETs will be better than transistors at these values.
well, it's not the best diagram I have ever seen, but still you can get an idea of the schematic. The most usefull link is mabe the comprehensive 163 chip datasheet, wich at least give you an idea of how the maytrix is driven.
ok! so maybe you could suggest an amplifier for your circuit, and that could apply to mine and others as well!!
Quote
well, to be honest my LED modules already have an internal resistor in order to make them work with 12V, so maybe this won't be a problem..
anyway you think something like this could work?
or you suggest a normal FET?
thanks again!!
as I thought, it's not so easy to 'boost' a matrix then, but I need to do it!!
That will work for one of the FETs, the one that pulls down, it is an N-channel one. You will also need a P-channel FET to source the power. As you want to drive 12V then the gate of this FET will have to be driven through a transistor or n-channel FET to get the 12V to 0V signal to turn it on and off.
So again lack of information hampers a sensible reply. What LED have you got? Module, strip, component, just what?
No you can't it is total pants. It is dishonest of the person to put it up and I would have nothing to do with him if it were me. At least a complaint would be going in. I assume it is a crude attempt to stop anyone copying the design, but something like that is deplorable.
ok, so, any suggestion for the p-channel fet?
Quote
but my question is about any 12V rgb led module, as the question here is not how much hefty the transistor must be , but how to connect it to a matrix driver.
to be honest I don't know about iteadstudio.com policy, but maybe this is something we should discuss somewhere else.
I was just wondering how to have fun with this (and maybe any other) matrix cirucit board, if someone can help...
I agree 100% with Grumpy_Mike about the schematic PDF. That is by far one of the worst I've ever seen. All the capacitor values are "???" and every resistor is "0R".....It's like getting someone 90% of a solution, then giving them the finger on the last 10%. The layout is mediocre, not very well organized, some part #'s/values are missing, sheet info is missing, some symbols are hard to understand. This thing is crud.
