how to drive DC motors on UNO pin 5 and 6
some1 put an article about it but i cant understand what he said. the link is http://playground.arduino.cc/Main/TimerPWMCheatsheet
Example: DC motor drive on the Arduino UNO, pins 5 and 6
For Fast PWM of 62.500 kHz (prescale factor of 1) Use these two lines in the setup function:
TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM01) | _BV(WGM00); TCCR0B = _BV(CS00);
And modify the line in the wiring.c function in the Arduino program files hardware\arduino\cores\arduino\wiring.c :
define MICROSECONDS_PER_TIMER0_OVERFLOW (clockCyclesToMicroseconds(1 * 256))
For Phase-correct PWM of 31.250 kHz (prescale factor of 1) Use these two lines in the setup function:
TCCR0A = _BV(COM0A1) | _BV(COM0B1) | _BV(WGM00); TCCR0B = _BV(CS00);
define MICROSECONDS_PER_TIMER0_OVERFLOW (clockCyclesToMicroseconds(1 * 510))
can some 1 tell me how to make it?
