Heres a cube, its similar to the cube I made. It use 64 leds controlled with 20 arduino pins.
Here is some code from a cube that uses 20 pins to control 64 leds
#include "xyz.h"
#define CUBESIZE 4
#define PLANESIZE CUBESIZE*CUBESIZE
#define REFRESH 100
int LEDPin[16] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15};
int LEDPinCount = 16;
int PlanePin[4] = {16, 17, 18, 19};
int PlanePinCount = 4;
boolean currentState[4][06] = {
{1, 0, 0, 1, 0, 1, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1},
{1, 0, 0, 1, 0, 1, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1},
{1, 0, 0, 1, 0, 1, 0, 0, 1, 0, 1, 1, 1, 1, 1, 1},
{1, 0, 0, 1, 0, 1, 0, 0, 0, 1, 0, 1, 1, 1, 1, 1}
}; // demo - initialized with this pattern
xyz neighbours[] = {{0,-1},{0,1},{4,0},{1,0},{-4,0},{-1,0}}; // use this to find possible neighbours
int pin; // loop counter
// set up LED pins as output (active LOW)
for (pin=0; pin<PLANESIZE; pin++) {
pinMode( LEDPin[pin], OUTPUT );
// set up plane pins as outputs (active HIGH)
for (pin=0; pin<CUBESIZE; pin++) {
pinMode( PlanePin[pin], OUTPUT );
//Serial.begin(9600);
setupState(); // randomize the state
void loop(){
drawState();
memcpy(previousState,currentState,64);
progressGame();
/*this calucaltes the next Game of Life gamestate according the rules beHIGH
*1. Any live cell with fewer than two live neighbours dies, as if caused by under-population.
*2. Any live cell with two or three live neighbours lives on to the next generation.
*3. Any live cell with more than three live neighbours dies, as if by overcrowding.
*4. Any dead cell with exactly three live neighbours becomes a live cell, as if by reproduction.
void progressGame(){
for(int y=0;y<4;y++){
for(int xz=0;xz<16;xz++){
xyz thisLED = {xz,y};
int numNeighbours = howManyNeighbours(thisLED);
if(numNeighbours < 2 && currentState[y][xz]){ //underpopulation
currentState[y][xz] = false;
else if(numNeighbours > 3 && currentState[y][xz]){ // overcrowding
else if(numNeighbours == 3 && !(currentState[y][xz])){ // reproduction
currentState[y][xz] = true;
else if(currentState[y][xz]){
else{
// core to the Game Of Life, this works out exactly what it says using previously written valid function
int howManyNeighbours(xyz led){
int numNeighbours = 0;
for(int e = 0;e<6;e++){ //iterate each possible neighbour
// is it out of bounds? and if not, is on?
xyz neighbourDirection = neighbours[e];
if(valid(led,neighbourDirection)){
xyz neighbour = move(led,neighbourDirection);
if(previousState[neighbour.y][neighbour.xz]){
numNeighbours++;
return numNeighbours;
void setupState(){
randomSeed(analogRead(20));
currentState[y][xz] = (int)random(2); //initiate every LED to random state
void drawState(){
long startTime = millis();
boolean draw = true;
while(draw){
digitalWrite(PlanePin[y],HIGH); // turn on this plane
digitalWrite(LEDPin[xz],currentState[y][xz]); // set it to wahtever the state says it should be
delay(2);
pinsOff();
digitalWrite(PlanePin[y],LOW); //turn off this plane before moving to the next one
if(millis() > startTime + REFRESH){
draw = false;
void pinsOff(){
for(int thisPin = 0; thisPin < PlanePinCount; thisPin++){
digitalWrite(LEDPin[thisPin],HIGH);
