How to dynamically change the parameter of 'step'?
Hi all.
the sketch works well to produce the sine wave.
I added the code try to control the step to vary its frequency dynamically failed, why?
the modified lines between:
//................................................add
Thanks
Adam
/* DAC Cosine Generator Example
   This example code is in the Public Domain (or CC0 licensed, at your option.)
   Unless required by applicable law or agreed to in writing, this
   software is distributed on an "AS IS" BASIS, WITHOUT WARRANTIES OR
   CONDITIONS OF ANY KIND, either express or implied.
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/queue.h"
#include "soc/rtc_io_reg.h"
#include "soc/rtc_cntl_reg.h"
#include "soc/sens_reg.h"
#include "soc/rtc.h"
#include "driver/dac.h"
/* Declare global sine waveform parameters
   so they may be then accessed and changed from debugger
   over an JTAG interface
// Esp32 @ 240 MHz:
// f=125.6*step/(div+1)            [div=0..7] [calc: (div+1)]
// step0:
// 0=15.61Hz 1=--
// step 1:
// 0 = 125.6 Hz 1 = 62.50 Hz 2 = 41.67Hz 3=31.35Hz 4=25.00Hz 5=20.92Hz 6=17.86Hz 7=15.63Hz
// step 2:125,6
// 0= 250.0 Hz 1=125Hz 2=83.68 Hz 3=62.5 Hz 4=50.1 Hz 5=41.74Hz  6=35.74 Hz  7=31.35Hz
// step 10
// 0 = 1.248 kHz 1 = 625.4 Hz 2 = 417.4 Hz (noisy) 3 = 31.33 Hz 4 = 250.6  5 = 208.3 Hz  6=178.9 7=156.3
// step 100:
// 0: 12.53 kHz  1 = 6.266 kHz 2=4.173kHz 3= 3.127 kHz 4=2.505 kHz 6=1.789 kHz 7=1.565KHz
// step 500:
// 0: 62.54 kHz (noisy) 1 = 31.33 kHz 2 = 20.86 kHz  5 = 10.5 kHz   6 =20.88 KhZ  7=
// step 1000:
// 0 = 125 kHz, 1 = 62.11 kHz, 5 = 20.73 kHz    ==>>> 10 = 42.02 kHz 100
// step 2000
// 0: 249.4 kHz(unten verzerrt)  1 = 125.8 kHz (noisy)  5 = 41.5 kHz (noisy)
int clk_8m_div = 1;      // RTC 8M clock divider (division is by clk_8m_div+1, i.e. 0 means 8MHz frequency)
int frequency_step = 7;  // Frequency step for CW generator
int scale = 1;           // 50% of the full scale // scale 0 == fill scale = bad signal (no longer a sine wave)
int offset;              // leave it default / 0 = no any offset
int invert = 2;          // invert MSB to get sine waveform  // 3: invert 180°
//...................... add
int stepSET = 0;
const int stepSETpot = 27;
   Enable cosine waveform generator on a DAC channel
void dac_cosine_enable(dac_channel_t channel)
  // Enable tone generator common to both channels
  SET_PERI_REG_MASK(SENS_SAR_DAC_CTRL1_REG, SENS_SW_TONE_EN);
  switch (channel) {
    case DAC_CHANNEL_1:
      // Enable / connect tone tone generator on / to this channel
      SET_PERI_REG_MASK(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_CW_EN1_M);
      // Invert MSB, otherwise part of waveform will have inverted
      SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_INV1, 2, SENS_DAC_INV1_S);
    case DAC_CHANNEL_2:
      SET_PERI_REG_MASK(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_CW_EN2_M);
      SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_INV2, 2, SENS_DAC_INV2_S);
    default :
      printf("Channel %d\n", channel);
   Set frequency of internal CW generator common to both DAC channels
   clk_8m_div: 0b000 - 0b111
   frequency_step: range 0x0001 - 0xFFFF
void dac_frequency_set(int clk_8m_div, int frequency_step)
  REG_SET_FIELD(RTC_CNTL_CLK_CONF_REG, RTC_CNTL_CK8M_DIV_SEL, clk_8m_div);
  SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL1_REG, SENS_SW_FSTEP, frequency_step, SENS_SW_FSTEP_S);
   Scale output of a DAC channel using two bit pattern:
   - 00: no scale
   - 01: scale to 1/2
   - 10: scale to 1/4
   - 11: scale to 1/8
void dac_scale_set(dac_channel_t channel, int scale)
  switch (channel) {
    case DAC_CHANNEL_1:
      SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_SCALE1, scale, SENS_DAC_SCALE1_S);
    case DAC_CHANNEL_2:
      SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_SCALE2, scale, SENS_DAC_SCALE2_S);
    default :
   Offset output of a DAC channel
   Range 0x00 - 0xFF
void dac_offset_set(dac_channel_t channel, int offset)
  switch (channel) {
    case DAC_CHANNEL_1:
      SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_DC1, offset, SENS_DAC_DC1_S);
    case DAC_CHANNEL_2:
      SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_DC2, offset, SENS_DAC_DC2_S);
    default :
   Invert output pattern of a DAC channel
   - 00: does not invert any bits,
   - 01: inverts all bits,
   - 10: inverts MSB,
   - 11: inverts all bits except for MSB
void dac_invert_set(dac_channel_t channel, int invert)
  switch (channel) {
    case DAC_CHANNEL_1:
      SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_INV1, invert, SENS_DAC_INV1_S);
    case DAC_CHANNEL_2:
      SET_PERI_REG_BITS(SENS_SAR_DAC_CTRL2_REG, SENS_DAC_INV2, invert, SENS_DAC_INV2_S);
    default :
   Main task that let you test CW parameters in action
void dactask(void* arg)
  double f, f_target, delta, delta_min = 9999999.0;
  int step_target = 0, divi_target = 0;
  //From experiments:  f=125.6*step/(div+1)
  // this frequency is wanted:
  f_target = 200000.0;                           // <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  // check all combinations of step iand divi to get the best guess:
  for (int step = 1; step < stepSET; step++) {  /// stepSET replaced 2000;
    for (int divi = 0; divi < 8; divi++) {
      f = 125.6 * (double)step / (double)(divi + 1);
      delta = abs((f_target - f));
      if (delta  < delta_min) {
        delta_min = delta;
        step_target = step;
        divi_target = divi;
  clk_8m_div = divi_target;
  frequency_step = step_target;
  printf("divi=%d step=%d\n", divi_target, step_target);
  while (1) {
    // frequency setting is common to both channels
    dac_frequency_set(clk_8m_div, frequency_step);
    /* Tune parameters of channel 2 only
       to see and compare changes against channel 1
    dac_scale_set(DAC_CHANNEL_2, scale);
    dac_offset_set(DAC_CHANNEL_2, offset);
    dac_invert_set(DAC_CHANNEL_2, invert);
    float frequency = RTC_FAST_CLK_FREQ_APPROX / (1 + clk_8m_div) * (float) frequency_step / 65536;
    printf("THEORIE:   clk_8m_div: %d, frequency step: %d, frequency: %.0f Hz\n", clk_8m_div, frequency_step, frequency);
    printf("PRACTICAL: frequency: %.0f Hz\n", 125.6 * (float)frequency_step / (1 + (float)clk_8m_div) );
    printf("DAC2 scale: %d, offset %d, invert: %d\n", scale, offset, invert);
    vTaskDelay(2000 / portTICK_PERIOD_MS);
  dac_cosine_enable(DAC_CHANNEL_1);
  dac_cosine_enable(DAC_CHANNEL_2);
  dac_output_enable(DAC_CHANNEL_1);
  dac_output_enable(DAC_CHANNEL_2);
  //.......................... add
  pinMode(stepSETpot, INPUT);
  stepSET = map(analogRead(stepSETpot), 0, 4095, 0, 2000);
  Serial.print("stepSET =");
  Serial.println(stepSET);
  xTaskCreate(dactask, "dactask", 1024 * 3, NULL, 10, NULL);
Failed, how?
failed to control the step to vary its frequency dynamically .
it run the code, but no response for the pot turning during the code run.
And that's what was missing from your description.
You set stepSET once during setup(). setup() runs once at startup. You can twiddle that pot til the cows come home but since you're not re-resding its analog input and updating stepSET while the program is running, nothing will change.
And with that, the lack of volatile isn't even an issue.
Great!
Thank you.
