How to easily plot data
I am doing measurements with an Arduino, and I would like to plot the columns of data that I get every time I run the sketch - which is often.
It seems impossible to draw them in the Arduino IDE, since from what I understand you can only plot real-time data in the Serial plotter. Apparently you can stream data into Excel, but it is not free.
I could save my data on a SD card and then plot it, but it takes a lot of clicking in between 2 experiences.
So I copy and paste the columns from the Serial monitor to OpenOffice Calc, but I wish I could have the data printed on my screen right after a measurement campaign is done.
Can you do this with an Arduino?
Thanks
I have been saving hourly weather data for a bit over 3 years to a dB, from there, it's easy to use some program, like a spreadsheet program, to plot the data.
My 13 ESP32's send their data to a MQTT Broker running on a RPi. The RPi put the MQTT data into a database for storage.
Your topic was MOVED to its current forum category which is more appropriate than the original as it is not an Introductory Tutorial
Create a Graph with Processing | Arduino Documentation | Arduino Documentation
Yes, using Excel on a Windows PC and the PLX-DAQ2 macro
