How to easily pulse 30 v , and then swap polarity and pulse again, in a loop?
Hi
I am experimenting with a project, and I am not skilled with electronics design.
I like to install an approx 30 volt AC trafo, control it with programmed Arduino Uno so it can do the following:
rectify the power to 30v DC and initiate a pulse with a given length. Then disconnect, and then pulse again with opposite polarity. Then disconnect and pulse with correct polarity. And so forth.
I can, of course, do this with relays but it will be worn out after a short time.
Is there someone who could give me a proposal of a simple design avoiding the relays?
sounds like you need a H Bridge driver (module) like this:
link
You will have to find one that fits your current requirements.
