How to edit a library for tcs34735 sensor
Hello fellow mates I would like to ask question in this below code I want to change the output of R G B provided by the sensor but when I directly minus the number to the unit16_t r,g,b; it gives nothing and changes back to normal is there any way to do this.
Here is the code
#include <Wire.h>
#include "Adafruit_TCS34725.h"
// I2C 7-bit address 0x29, 8-bit address 0x52
// http://www.adafruit.com/product/1334
// http://learn.adafruit.com/adafruit-color-sensors/overview
// http://www.adafruit.com/datasheets/TCS34725.pdf
// http://www.ams.com/eng/Products/Light-Sensors/Color-Sensor/TCS34725
// http://www.ams.com/eng/content/view/download/265215 <- DN40, calculations
// http://www.ams.com/eng/content/view/download/181895 <- DN39, some thoughts on autogain
// http://www.ams.com/eng/content/view/download/145158 <- DN25 (original Adafruit calculations)
// connect LED to digital 4 or GROUND for ambient light sensing
// connect SCL to analog 5
// connect SDA to analog 4
// connect Vin to 3.3-5V DC
// connect GROUND to common ground
// some magic numbers for this device from the DN40 application note
#define TCS34725_R_Coef 0.136
#define TCS34725_G_Coef 1.000
#define TCS34725_B_Coef -0.444
#define TCS34725_GA 1.0
#define TCS34725_DF 310.0
#define TCS34725_CT_Coef 3810.0
#define TCS34725_CT_Offset 1391.0
int l;
// Autorange class for TCS34725
class tcs34725 {
private:
  struct tcs_agc {
    tcs34725Gain_t ag;
    uint8_t at;
    uint16_t mincnt;
    uint16_t maxcnt;
  static const tcs_agc agc_lst[];
  uint16_t agc_cur;
  void setGainTime(void);
  Adafruit_TCS34725 tcs;
public:
  tcs34725(void);
  boolean begin(void);
  void getData(void);
  boolean isAvailable, isSaturated;
  uint16_t againx, atime, atime_ms;
  uint16_t r, g, b, c;
  uint16_t ir;
  uint16_t r_comp, g_comp, b_comp, c_comp;
  uint16_t saturation, saturation75;
  float cratio, cpl, ct, lux, maxlux;
// Gain/time combinations to use and the min/max limits for hysteresis
// that avoid saturation. They should be in order from dim to bright.
// Also set the first min count and the last max count to 0 to indicate
// the start and end of the list.
const tcs34725::tcs_agc tcs34725::agc_lst[] = {
  { TCS34725_GAIN_60X, TCS34725_INTEGRATIONTIME_614MS,     0, 20000 },
  { TCS34725_GAIN_60X, TCS34725_INTEGRATIONTIME_154MS,  4990, 63000 },
  { TCS34725_GAIN_16X, TCS34725_INTEGRATIONTIME_154MS, 16790, 63000 },
  { TCS34725_GAIN_4X,  TCS34725_INTEGRATIONTIME_154MS, 15740, 63000 },
  { TCS34725_GAIN_1X,  TCS34725_INTEGRATIONTIME_154MS, 15740, 0 }
tcs34725::tcs34725() : agc_cur(0), isAvailable(0), isSaturated(0) {
// initialize the sensor
boolean tcs34725::begin(void) {
  tcs = Adafruit_TCS34725(agc_lst[agc_cur].at, agc_lst[agc_cur].ag);
  if ((isAvailable = tcs.begin()))
    setGainTime();
  return(isAvailable);
// Set the gain and integration time
void tcs34725::setGainTime(void) {
  tcs.setGain(agc_lst[agc_cur].ag);
  tcs.setIntegrationTime(agc_lst[agc_cur].at);
  atime = int(agc_lst[agc_cur].at);
  atime_ms = ((256 - atime) * 2.4);
  switch(agc_lst[agc_cur].ag) {
  case TCS34725_GAIN_1X:
    againx = 1;
  case TCS34725_GAIN_4X:
    againx = 4;
  case TCS34725_GAIN_16X:
    againx = 16;
  case TCS34725_GAIN_60X:
    againx = 60;
// Retrieve data from the sensor and do the calculations
void tcs34725::getData(void) {
  // read the sensor and autorange if necessary
  tcs.getRawData(&r, &g, &b, &c);
  while(1) {
    if (agc_lst[agc_cur].maxcnt && c > agc_lst[agc_cur].maxcnt)
      agc_cur++;
    else if (agc_lst[agc_cur].mincnt && c < agc_lst[agc_cur].mincnt)
      agc_cur--;
    else break;
    setGainTime();
    delay((256 - atime) * 2.4 * 2); // shock absorber
  // DN40 calculations
  l=80;
  ir = (r + g + b > c) ? (r + g + b - c) / 2 : 0;
  r_comp = r - ir;
  g_comp = g - ir;
  b_comp = b - l;
  c_comp = c - ir;
  cratio = float(ir) / float(c);
  saturation = ((256 - atime) > 63) ? 65535 : 1024 * (256 - atime);
  saturation75 = (atime_ms < 150) ? (saturation - saturation / 4) : saturation;
  isSaturated = (atime_ms < 150 && c > saturation75) ? 1 : 0;
  cpl = (atime_ms * againx) / (TCS34725_GA * TCS34725_DF);
  maxlux = 65535 / (cpl * 3);
  lux = (TCS34725_R_Coef * float(r_comp) + TCS34725_G_Coef * float(g_comp) + TCS34725_B_Coef * float(b_comp)) / cpl;
  ct = TCS34725_CT_Coef * float(b_comp) / float(r_comp) + TCS34725_CT_Offset;
tcs34725 rgb_sensor;
void setup(void) {
  rgb_sensor.begin();
  pinMode(4, OUTPUT);
  digitalWrite(4, LOW); // @gremlins Bright light, bright light!
void loop(void) {
  rgb_sensor.getData();
  Serial.print(F("Gain:"));
  Serial.print(rgb_sensor.againx);
  Serial.print(F("x "));
  Serial.print(F("Time:"));
  Serial.print(rgb_sensor.atime_ms);
  Serial.print(F("ms (0x"));
  Serial.print(rgb_sensor.atime, HEX);
  Serial.println(F(")"));
  Serial.print(F("Raw R:"));
  Serial.print(rgb_sensor.r);
  Serial.print(F(" G:"));
  Serial.print(rgb_sensor.g);
  Serial.print(F(" B:"));
  Serial.print(rgb_sensor.b);
  Serial.print(F(" C:"));
  Serial.println(rgb_sensor.c);
  Serial.print(F("IR:"));
  Serial.print(rgb_sensor.ir);
  Serial.print(F(" CRATIO:"));
  Serial.print(rgb_sensor.cratio);
  Serial.print(F(" Sat:"));
  Serial.print(rgb_sensor.saturation);
  Serial.print(F(" Sat75:"));
  Serial.print(rgb_sensor.saturation75);
  Serial.print(F(" "));
  Serial.println(rgb_sensor.isSaturated ? "*SATURATED*" : "");
  Serial.print(F("Lux:"));
  Serial.print(rgb_sensor.lux);
  Serial.print(F(" CT:"));
  Serial.print(rgb_sensor.ct);
  Serial.println(F("K"));
  delay(0);
In this i would like to customise the data received to me thanks.
I didn’t really understand what you want to achieve. Why change the sensor readings? are they wrong?
You write that you tried to change. Show where you do it in the code,
Hi I'm an absolute new here, the problem is that my sensor is obsessive with B data and I want to reduce it so to make a equilibrium with others
OK
That's what I was asking mate how to change that in this code . Let me make this clear that I am asking how to make changes in this library which element I have to change to get the results.
Thanks
And I directly put -80 at //dn40 calculation. There is a l that contain -80 . Is that how it is done (edit)
The thing is that we think there is no need to actually change the library. What you can do is to change any value you like once you get it from the library and before you apply it in your code.
It is that code we would like to see because you said you have tried to do this and failed. So finding out why this "normal" approach failed for you is much more useful than changing the library.
And let me make it clear that this is not the way to go about your problem.
Thanks this is what I was asking. So i just have to change the value after getting it either by storing it to another int?
Yes, that seems by far the simplest way. There is no need to even store it to an int you can adjust the variables you get back with a simple arithmetic operation, with your returned value on the left and a -=, +=, or what ever on the other side.
blueValue -= 42; // or what ever number you want to subtract
