Hi, first time I've run into a problem I haven't been able to solve through tutorials and reading previous posts. I've been stuck on this for 3 days now, and I'm hoping someone here will be able to clear the fog!
I'm not sure if the title accurately states the problem, let me know if I should change it.
I have two applications (smart bathroom fan through Sonoff Basic/ESP8285) which do the same thing at the same time, using the same code. Currently I'm keeping two parallel copies of the code with different IP addresses, OTA and mDNS names, which is a pain when I make tweaks to the code. I thought it would be smarter to instead use the same code, and just have a config file saved on each that then tells the code which settings to use.
I've followed the ArduinoJSON tutorial on doing this and it works for setting the IP address, but have run into a snag with changing the names. As I understand it, this is because those variables are passed as pointers, while the example is using a char array.
I've tried numerous ways to try and get this work, most wouldn't compile, the example I'm putting here did at least compile, but didn't change the variable. For simplicity the example only tries to change OTAName, as I figure it's exactly problem for both names.
Variable declarations:
char* mdnsName = "BathroomFan";
char* OTAName = "BathroomFan";
Attempting to change them:
// Copy values from the JsonDocument to the Config
const char *tempChar = doc["OTAName"];
*OTAName = *tempChar;
Serial.println(tempChar);
staticIP[3] = doc["StaticIP"];
I think the problem is in the above lines of code, but here is the full code and JSON for diagnosis.
#include <ESP8266WiFi.h> // for WiFi
#include <ArduinoOTA.h> // for OTA updates
#include <FS.h> // for SPIFFs file server
#include <ArduinoJson.h> // for JSON support
#define BOARD_LED 13 // On board LED is on GPIO13
IPAddress staticIP(192, 168, 0, 250);
// WiFi and server variables
const char *ssid = "ssid";
const char *password = "password";
char* OTAName = "BathroomFan"; // A name and a password for the OTA service
const char *OTAPassword = "password";
Serial.begin(9600); // Enable serial port
SPIFFS.begin(); // Start the SPI Flash File System (SPIFFS)
loadConfiguration(); // load the settings from flash memory
startWiFi(); // Start the WiFi
startOTA(); // Start the OTA service
ArduinoOTA.handle(); // listen for OTA events
void startOTA() { // Start the OTA service
ArduinoOTA.setHostname(OTAName);
ArduinoOTA.setPassword(OTAPassword);
ArduinoOTA.begin();
// Loads the configuration from a file
void loadConfiguration() {
// Open file for reading
File file = SPIFFS.open("/Config.json", "r");
Serial.println("Initial values of variables");
Serial.println(OTAName);
// Allocate a temporary JsonDocument
StaticJsonDocument<512> doc;
// Deserialize the JSON document
DeserializationError error = deserializeJson(doc, file);
if (error)
Serial.println(F("Failed to read file, using default configuration"));
Serial.println("Modified values of variables");
Serial.println(staticIP);
// Close the file (Curiously, File's destructor doesn't close the file)
file.close();
void startWiFi() { // Start a Wi-Fi access point, and try to connect to some given access points. Then wait for either an AP or STA connection
WiFi.begin(ssid, password); // Start WiFi
int timer = 0;
while (WiFi.status() != WL_CONNECTED && timer < 200)
delay(100);
digitalWrite(BOARD_LED, !digitalRead(BOARD_LED));
timer ++; // If wifi is not available, continue with boot up
WiFi.config(staticIP, WiFi.gatewayIP(), WiFi.subnetMask()); // set up the fixed IP address, in case mDNS doesn't work
JSON
"OTAName": "BathroomFan2",
"mdnsName": "BathroomFan",
"StaticIP": 213,
"target_humidity": 90,
"hysteresis": 9,
"minimum_run": 10
