How to edit code from Node-Red to Cayenne
I am working on a project to run some (relays or LED's) on an inputs (Pins) Arduino by esp8266-01s . now while searching on internet I found a video divided it two step that talks about the issue using a ESP8266-01. The important thing in the topic is that the person uses two codes for project :
  1. The first code for esp8266.
  2. The second code for arduino uno.
The most important part of the topic I want to modify the code for esp8266 . but the owner of the video uses node red website and I want to use the cayenne website . I want to specify basic commands to modify in order to work on cayenne website .
I play with esp and arduino in order to project offline.
first video : #1 ESP8266+ Arduino Nano + Relay via Serial - MQTT Node Red - YouTube
second video : #2 part2 ESP8266+ Arduino Nano + Relay via Serial - MQTT Node Red - YouTube
#include <PubSubClient.h>
 #include <ESP8266WiFi.h>
 //EDIT THESE LINES TO MATCH YOUR SETUP
 #define MQTT_SERVER "192.168.1.117"  ///YourMQTTBroker'sIP
 const char* ssid = "Weems_2GHz";
 const char* password = "1029384756";
 char* Topic = "inTopic"; //subscribe to topic to be notified about
 WiFiClient wifiClient;
 //initialize the light as an output and set to LOW (off)
 //start the serial line for debugging
 delay(100);
//start wifi subsystem
WiFi.begin(ssid, password);
//attempt to connect to the WIFI network and then connect to the MQTT server
reconnect();
//wait a bit before starting the main loop
  delay(2000);
PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
void loop(){
//reconnect if connection is lost
if (!client.connected() && WiFi.status() == 3) {reconnect();}
//maintain MQTT connection
client.loop();
//MUST delay to allow ESP8266 WIFI functions to run
delay(20);
void callback(char* topic, byte* payload, unsigned int length) {
//convert topic to string to make it easier to work with
String topicStr = topic;
//Print out some debugging info
////Serial.println("Callback update.");
//Serial.print("Topic: ");
//Serial.println(topicStr);
//turn the light off if the payload is '0' and publish to the MQTT server a confirmation message
if (payload[0] == '0'){
Serial.print("0");
respond();}
if(payload[0] == '1'){
Serial.print("1");
respond();}
if (payload[0] == '2'){
Serial.print("2");
respond();}
if(payload[0] == '3'){
Serial.print("3");
respond();}
if (payload[0] == '4'){
Serial.print("4");
respond();}
if(payload[0] == '5'){
Serial.print("5");
respond();}
if (payload[0] == '6'){
Serial.print("6");
respond();}
if(payload[0] == '7'){
Serial.print("7");
respond();
void respond(){
delay(5);
if (Serial.available()) {
//read serial as a character
char ser = Serial.read();
switch (ser) {
  case 'a':
client.publish("outTopic", "Relay 1 is ON");
  case 'b':
client.publish("outTopic", "Relay 1 is OFF");
  case 'c':
client.publish("outTopic", "Relay 2 is ON");
  case 'd':
client.publish("outTopic", "Relay 2 is OFF");
  case 'e':
client.publish("outTopic", "Relay 3 is ON");
  case 'f':
client.publish("outTopic", "Relay 3 is OFF");
  case 'g':
client.publish("outTopic", "Relay 4 is ON");
  case 'h':
client.publish("outTopic", "Relay 4 is OFF");
}//switch
}//if
}//void
void reconnect() {
//attempt to connect to the wifi if connection is lost
if(WiFi.status() != WL_CONNECTED){
//make sure we are connected to WIFI before attemping to reconnect to MQTT
if(WiFi.status() == WL_CONNECTED){
// Loop until we're reconnected to the MQTT server
while (!client.connected()) {
  //Serial.print("Attempting MQTT connection...");
  // Generate client name based on MAC address and last 8 bits of microsecond counter
  String clientName;
  clientName += "esp8266-";
  uint8_t mac[6];
  WiFi.macAddress(mac);
  clientName += macToStr(mac);
  //if connected, subscribe to the topic(s) we want to be notified about
  if (client.connect((char*) clientName.c_str())) {
    Serial.print("\tMTQQ Connected");
    client.subscribe(Topic);
  //otherwise print failed for debugging
  else{Serial.println("\tFailed."); abort();}
  //generate unique name from MAC addr
  String macToStr(const uint8_t* mac){
  String result;
  for (int i = 0; i < 6; ++i) {
  result += String(mac[i], 16);
  if (i < 5){
  result += ':';
  return result;
answer me
you want
you want
Demands will get you nowhere on this forum.
Learn to ask nicely.
You are the one being PAID to do the job; not us.
What is actually your question? Does your code work? If not, what error do you get?
I cannot find the wiring diagram of your setup!
Don't you think a link to that "cayenne" website is necessary for us to be even able to help you?
