How to edit SDISerial from AVR board (Arduino Uno) to SARM board (MKR 1010 WiFi)?
Hi all,
My current coding for the <SDISerial.h> is for Arduino Uno and I wish to change to Arduino MKR WiFi 1010 Arduino MKR WiFi 1010 Datasheet. How to change the code from Arduino Uno to Arduino MKR WiFi 1010.
/* code reads Decagon GS3 sensor output to the serial terminal.
WHITE wire: power supply/excitation, connected to 5v pin
RED wire: data line, connected to Arduino pin 2 (or another interrupt-capable pin)
bare wire: connected to GND
#include <SDISerial.h>
#define INPUT_SIZE 30
#define NUMSAMPLES 5
#define INVERTED 1
#define DATA_PIN 4
int sensorDelay = 1000;
// bulk density used to calculate porewater conductivity (g/cm3)
float bulkDens = 0.4;
// mineral density assumed to be 2.65 Mg/m3 (used
// in porewater calculation from eq. 3 from GS-3 manual)
float theta = 1 - (bulkDens / 2.65);
char* samples;
SDISerial sdi_serial_connection(DATA_PIN, INVERTED);
  sdi_serial_connection.begin();
  Serial.begin(921600);
  Serial.println("Start Initialized\n");
  uint8_t i;
  // arrays to hold reps
  float dielectric[NUMSAMPLES];
  float soilMoist[NUMSAMPLES];
  float degC[NUMSAMPLES];
  float bulkEC[NUMSAMPLES];
  float porewaterEC[NUMSAMPLES];
  float solutionEC[NUMSAMPLES];
  // mean values
  float dielMean        = 0.0;
  float soilMoistMean   = 0.0;
  float degCMean        = 0.0;
  float bulkECMean      = 0.0;
  float porewaterECMean = 0.0;
  float solutionECMean  = 0.0;
  // take repeated samples
  for (i = 0; i < NUMSAMPLES; i++) {
    //char* response = get_measurement(); // get measurement data
    samples = get_measurement();
    while (strlen(samples) < 5) {
    // first term is the sensor address (irrelevant to me)
    char* term1 = strtok(samples, "+");
    // second term is the dielectric conductivity & soil moisture
    term1      = strtok(NULL, "+");
    dielectric[i] = atof(term1);
    degC[i] = atof(term1);
    bulkEC[i] = atof(term1);
    // see eqs. 1 + 2 from GS3 manual (dS/m)
    porewaterEC[i] = ((80.3 - 0.37 * (degC[i] - 20)) * bulkEC[i] / 1000) / (dielectric[i] - 6);
   if (bulkEC[i] < 5) {
     soilMoist[i]  = (5.89 * pow(10.0, -6.0) * pow(dielectric[i], 3.0)) - (7.62 * pow(10.0, -4.0) *
     pow(dielectric[i], 2.0)) + (3.67 * pow(10.0, -2.0) * dielectric[i]) - (7.53 * pow(10.0, -2.0));
   soilMoist[i]  =  0.118 * sqrt(dielectric[i]) -0.117;
    // calculate EC of solution removed from a saturated soil paste,
    // according to Decagon GS3 manual
    // see page 8 of GS3 manual (eq. 4)
    solutionEC[i] =  (bulkEC[i] / 1000 * soilMoist[i]) / theta;
    // sum with each iteration
    dielMean        += dielectric[i];
    soilMoistMean   += soilMoist[i];
    degCMean        += degC[i];
    bulkECMean      += bulkEC[i];
    porewaterECMean += porewaterEC[i];
    solutionECMean  += solutionEC[i];
  // Average readings for each parameter
  dielMean        /= NUMSAMPLES;
  soilMoistMean   /= NUMSAMPLES;
  degCMean        /= NUMSAMPLES;
  bulkECMean      /= (NUMSAMPLES / 0.001);
  porewaterECMean /= NUMSAMPLES;
  solutionECMean  /= NUMSAMPLES;
//  Serial.print("dielectric: ");
//  Serial.println(dielMean, 3);
  Serial.print("VWC (m3/m3): ");
  Serial.println(soilMoistMean, 3);
  Serial.print("Degree (C): ");
  Serial.println(degCMean, 1);
  Serial.print("bulk EC (dS/m): ");
  Serial.println(bulkECMean, 3);
//  Serial.print("Solution EC (dS/m): ");
//  Serial.println(solutionECMean, 4);
//  Serial.print("porewater EC (dS/m): ");
//  Serial.println(porewaterECMean, 4);
  delay(sensorDelay);
  Serial.println("\n");
char* get_measurement(){
        // function by Joran Beasley: https://github.com/joranbeasley/SDISerial/blob/master/examples/SDISerialExample/SDISerialExample.ino
    char* service_request = sdi_serial_connection.sdi_query("?M!", sensorDelay);
    //you can use the time returned above to wait for the service_request_complete
    char* service_request_complete = sdi_serial_connection.wait_for_response(sensorDelay);
    // 1 second potential wait, but response is returned as soon as it's available
    return sdi_serial_connection.sdi_query("?D0!", sensorDelay);
After trying to upload the code, I got error as shown below.
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:126:2: error: #error This version of SoftwareSerial supports only 20, 16 and 8MHz processors
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'bool SDISerial::listen()':
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:189:23: error: 'SREG' was not declared in this scope
     uint8_t oldSREG = SREG;
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:189:23: note: suggested alternative: 'SING'
                       SING
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:190:5: error: 'cli' was not declared in this scope
     cli();
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:190:5: note: suggested alternative: 'Gclk'
     cli();
     Gclk
In file included from C:\Users\matebook\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/Arduino.h:51:0,
                 from C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:43:
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'void SDISerial::setTX(uint8_t)':
C:\Users\matebook\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrwifi1010/variant.h:49:35: error: invalid conversion from 'PortGroup*' to 'uint8_t {aka unsigned char}' [-fpermissive]
 #define digitalPinToPort(P)      (&(PORT->Group[g_APinDescription[P].ulPort]))
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:365:18: note: in expansion of macro 'digitalPinToPort'
   uint8_t port = digitalPinToPort(tx);
C:\Users\matebook\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrwifi1010/variant.h:52:41: error: base operand of '->' is not a pointer
 #define portOutputRegister(port) (&(port->OUT.reg))
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:366:27: note: in expansion of macro 'portOutputRegister'
   _transmitPortRegister = portOutputRegister(port);
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'void SDISerial::sdi_cmd(const char*)':
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:376:20: error: 'SREG' was not declared in this scope
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:376:20: note: suggested alternative: 'SING'
                    SING
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'char* SDISerial::service_request(const char*, const char*)':
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:410:70: error: ISO C++ forbids comparison between pointer and integer [-fpermissive]
  if (service_request_response == NULL || service_request_response == '\0')return NULL;
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'void SDISerial::setRX(uint8_t)':
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:421:18: note: in expansion of macro 'digitalPinToPort'
   uint8_t port = digitalPinToPort(rx);
C:\Users\matebook\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrwifi1010/variant.h:53:41: error: base operand of '->' is not a pointer
 #define portInputRegister(port)  (&(port->IN.reg))
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:422:26: note: in expansion of macro 'portInputRegister'
   _receivePortRegister = portInputRegister(port);
In file included from C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:42:0:
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'void SDISerial::begin()':
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:431:41: error: 'table' was not declared in this scope
    _rx_delay_centering = pgm_read_word(&table[0].rx_delay_centering);
C:\Users\matebook\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp/avr/pgmspace.h:103:56: note: in definition of macro 'pgm_read_word'
 #define pgm_read_word(addr) (*(const unsigned short *)(addr))
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:431:41: note: suggested alternative: 'tanl'
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:441:6: error: 'digitalPinToPCICR' was not declared in this scope
  if (digitalPinToPCICR(_receivePin))
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:441:6: note: suggested alternative: 'digitalPinToPort'
      digitalPinToPort
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:443:43: error: 'digitalPinToPCICRbit' was not declared in this scope
    *digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin));
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:443:43: note: suggested alternative: 'digitalPinToPort'
                                           digitalPinToPort
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:443:39: error: '_BV' was not declared in this scope
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:443:39: note: suggested alternative: '_B'
                                       _B
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:444:5: error: 'digitalPinToPCMSK' was not declared in this scope
    *digitalPinToPCMSK(_receivePin) |= _BV(digitalPinToPCMSKbit(_receivePin));
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:444:5: note: suggested alternative: 'digitalPinToPort'
     digitalPinToPort
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:444:43: error: 'digitalPinToPCMSKbit' was not declared in this scope
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:444:43: note: suggested alternative: 'digitalPinToPort'
                                           digitalPinToPort
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'void SDISerial::end()':
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:459:7: error: 'digitalPinToPCMSK' was not declared in this scope
   if (digitalPinToPCMSK(_receivePin))
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:459:7: note: suggested alternative: 'digitalPinToPort'
       digitalPinToPort
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:460:45: error: 'digitalPinToPCMSKbit' was not declared in this scope
     *digitalPinToPCMSK(_receivePin) &= ~_BV(digitalPinToPCMSKbit(_receivePin));
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:460:45: note: suggested alternative: 'digitalPinToPort'
                                             digitalPinToPort
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:460:41: error: '_BV' was not declared in this scope
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:460:41: note: suggested alternative: '_B'
                                         _B
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'virtual size_t SDISerial::write(uint8_t)':
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:516:21: error: 'SREG' was not declared in this scope
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:516:21: note: suggested alternative: 'SING'
                     SING
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:517:3: error: 'cli' was not declared in this scope
   cli();  // turn off interrupts for a clean txmit
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:517:3: note: suggested alternative: 'Gclk'
   Gclk
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:521:26: error: 'XMIT_START_ADJUSTMENT' was not declared in this scope
   tunedDelay(_tx_delay + XMIT_START_ADJUSTMENT);
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp: In member function 'virtual void SDISerial::flush()':
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:571:21: error: 'SREG' was not declared in this scope
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:571:21: note: suggested alternative: 'SING'
                     SING
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:572:3: error: 'cli' was not declared in this scope
   cli();
C:\Users\matebook\Documents\Arduino\libraries\SDISerial-master\SDISerial.cpp:572:3: note: suggested alternative: 'Gclk'
   cli();
   Gclk
exit status 1
Error compiling for board Arduino MKR WiFi 1010.
How to change the code, so that it is possible to run in Arduino MKR WiFi 1010.
Thanks.
Regards,
Storm
