Hi, I have a GPS device that does not have a RS232 serial port, it only has a USB port to connect to a PC, I want to use the USB OTG port of the ESP32-S2 to connect to the GPS to read the data and configure it, I have done tests with this USBSerial code example that emulates a serial port, it runs OK, the PC recognizes it and I can communicate in both directions, I can send and receive text strings, but when I connect it to the GPS it does not recognize it, the connection is not achieved logical connection, could someone give me some suggestion on how to run this
This is log when I connect the PC:
and this is log when I connect it to the GPS:
Heres is the code:
#if ARDUINO_USB_MODE
#warning This sketch should be used when USB is in OTG mode
void setup(){}
void loop(){}
#else
#include "USB.h"
#if ARDUINO_USB_CDC_ON_BOOT
#define HWSerial Serial0
#define USBSerial Serial
#else
USBCDC USBSerial;
#endif
static void usbEventCallback(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data){
if(event_base == ARDUINO_USB_EVENTS){
arduino_usb_event_data_t * data = (arduino_usb_event_data_t*)event_data;
switch (event_id){
case ARDUINO_USB_STARTED_EVENT:
HWSerial.println("USB PLUGGED");
case ARDUINO_USB_STOPPED_EVENT:
HWSerial.println("USB UNPLUGGED");
case ARDUINO_USB_SUSPEND_EVENT:
HWSerial.printf("USB SUSPENDED: remote_wakeup_en: %u\n", data->suspend.remote_wakeup_en);
case ARDUINO_USB_RESUME_EVENT:
HWSerial.println("USB RESUMED");
default:
} else if(event_base == ARDUINO_USB_CDC_EVENTS){
arduino_usb_cdc_event_data_t * data = (arduino_usb_cdc_event_data_t*)event_data;
switch (event_id){
case ARDUINO_USB_CDC_CONNECTED_EVENT:
HWSerial.println("CDC CONNECTED");
case ARDUINO_USB_CDC_DISCONNECTED_EVENT:
HWSerial.println("CDC DISCONNECTED");
case ARDUINO_USB_CDC_LINE_STATE_EVENT:
HWSerial.printf("CDC LINE STATE: dtr: %u, rts: %u\n", data->line_state.dtr, data->line_state.rts);
case ARDUINO_USB_CDC_LINE_CODING_EVENT:
HWSerial.printf("CDC LINE CODING: bit_rate: %u, data_bits: %u, stop_bits: %u, parity: %u\n", data->line_coding.bit_rate, data->line_coding.data_bits, data->line_coding.stop_bits, data->line_coding.parity);
case ARDUINO_USB_CDC_RX_EVENT:
HWSerial.printf("CDC RX [%u]:", data->rx.len);
uint8_t buf[data->rx.len];
size_t len = USBSerial.read(buf, data->rx.len);
HWSerial.write(buf, len);
HWSerial.println();
case ARDUINO_USB_CDC_RX_OVERFLOW_EVENT:
HWSerial.printf("CDC RX Overflow of %d bytes", data->rx_overflow.dropped_bytes);
default:
HWSerial.begin(115200);
HWSerial.setDebugOutput(true);
USB.onEvent(usbEventCallback);
USBSerial.onEvent(usbEventCallback);
USBSerial.begin();
USB.begin();
while(HWSerial.available()){
size_t l = HWSerial.available();
uint8_t b[l];
l = HWSerial.read(b, l);
USBSerial.write(b, l);
#endif /* ARDUINO_USB_MODE */
