Hello,
I am writing an ARDUINO Robot application using Windows MFC/Win32 in Visual Studio.
Some of these VS project cpp/h files I want to become part of an IDE2 Arduino sketch.
So I have created a .ino file in the VS project folder and made it the same name as VS the project name.
However when I open the .ino with IDE2 it imports all the VS cpp/h files.
Problem is many of these cpp/h files are Windows MFC/Win32 specific and are not wanted in the Arduino build. Is there a way to exclude the unwanted MFC/Win32 cpp/h from the Arduino IDE2 build please?
Many thanks in advance IMK
The sketch builder will compile all the source in
- the sketch root, which contains the
.ino
- in the "
src
" subdirectory- and all of its subdirectories
- But it will ignore all other subdirectories
- in the "
So if you can arrange your project so that the Windows-specific stuff is under "windows
" for example, that would be easiest. All the common stuff would be under "src
After that you'd use the regular method of doing cross-platform stuff in the same file: using #ifdef ARDUINO
for the Arduino stuff, and whatever the equivalent is on Windows.
Copy the files to the sketch directory.
