Hi
I dont get my head around how to make a LoRa receiver code execute commands only when new LoRa paket is red and content of pakage contains certain defined data.
I understand that readpacket() must run continuously to receive all packages, but my functions that is based on 'two demands = true' execute other commands, like write to cayenne, and to oled, and to ftp etc.
I receive a LoRa packet that has this data:
String LoRaMessage = String(packetID) + "/" + String(temperature) + "&" + String(humidity) + "£" + String(weight_median) + "#" + String(alarmValue) + "%" + String(hiveNr);
I ask for some help to set up a if (or while) statement in void loop() that goes like this:
When new packet red and packet contains hiveNr==1 and packetID is bigger than previous package then run function:
Cayenne.loop();
I have tried a bit but not finished, here is code to check change in paketID:
if (packetID_i > previousPacketID_i) {
Cayenne.loop();
PacketID is from this parsing function:
void readPacket() {
//try to parse packet
int packetSize = LoRa.parsePacket();
if (packetSize) {
while (LoRa.available())
LoRaMessage = LoRa.readString();
previousPacketID_i = packetID.toInt();
int pos1 = LoRaMessage.indexOf('/'); //PacketID
int pos2 = LoRaMessage.indexOf('&'); //temp
int pos3 = LoRaMessage.indexOf('£'); //hum
int pos4 = LoRaMessage.indexOf('#'); //vekt_median
int pos5 = LoRaMessage.indexOf('%'); // alarm
int pos6 = LoRaMessage.indexOf('@'); // hiveNr - not send to cayenne
packetID = LoRaMessage.substring(0, pos1);
temperature = LoRaMessage.substring(pos1 + 1, pos2);
humidity = LoRaMessage.substring(pos2 + 1, pos3);
weight = LoRaMessage.substring(pos3 + 1, pos4);
alarmValue = LoRaMessage.substring(pos4 + 1, pos5);
hiveName = LoRaMessage.substring(pos5 + 1, LoRaMessage.length());
// convert to floatInt before sending to Cayenne
packetID_i = packetID.toInt();
temperature_f = temperature.toFloat();
humidity_f = humidity.toFloat();
weight_f = weight.toFloat();
//tareValue_i = tareValue.toInt();
alarmValue_i = alarmValue.toInt();
hiveName_i = hiveName.toInt();
