Hi all! I am a new Arduino user who is trying to create a complex problem on a short deadline. I've bought some Atlas Scientific Sensors and copied their Arduino Mega code, but want to use it on the Arduino Giga r1 wifi board. I'm wondering why this code works on the Mega but not the giga and if anyone has any suggestions.
String inputstring = ""; //a string to hold incoming data from the PC
String sensorstring = ""; //a string to hold the data from the Atlas Scientific product
boolean input_string_complete = false; //have we received all the data from the PC
boolean sensor_string_complete = false; //have we received all the data from the Atlas Scientific product
float DO; //used to hold a floating point number that is the DO
void setup() { //set up the hardware
Serial.begin(9600); //set baud rate for the hardware serial port_0 to 9600
Serial4.begin(9600); //set baud rate for software serial port_3 to 9600
// inputstring.reserve(10); //set aside some bytes for receiving data from the PC
// sensorstring.reserve(30); //set aside some bytes for receiving data from Atlas Scientific product
void serialEvent() { //if the hardware serial port_0 receives a char
inputstring = Serial.readStringUntil(13); //read the string until we see a <CR>
input_string_complete = true; //set the flag used to tell if we have received a completed string from the PC
void serialEvent3() { //if the hardware serial port_3 receives a char
sensorstring = Serial4.readStringUntil(13); //read the string until we see a <CR>
sensor_string_complete = true; //set the flag used to tell if we have received a completed string from the PC
void loop() { //here we go...
if (input_string_complete == true) { //if a string from the PC has been received in its entirety
Serial4.print(inputstring); //send that string to the Atlas Scientific product
Serial4.print('\r'); //add a <CR> to the end of the string
inputstring = ""; //clear the string
input_string_complete = false; //reset the flag used to tell if we have received a completed string from the PC
if (sensor_string_complete == true) { //if a string from the Atlas Scientific product has been received in its entirety
Serial.println(sensorstring); //send that string to the PC's serial monitor
/* //uncomment this section to see how to convert the D.O. reading from a string to a float
if (isdigit(sensorstring[0])) { //if the first character in the string is a digit
DO = sensorstring.toFloat(); //convert the string to a floating point number so it can be evaluated by the Arduino
if (DO >= 6.0) { //if the DO is greater than or equal to 6.0
Serial.println("high"); //print "high" this is demonstrating that the Arduino is evaluating the DO as a number and not as a string
if (DO <= 5.99) { //if the DO is less than or equal to 5.99
Serial.println("low"); //print "low" this is demonstrating that the Arduino is evaluating the DO as a number and not as a string
sensorstring = ""; //clear the string:
sensor_string_complete = false; //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
