How to exit loops
Here is a my sketch in general:
  while (...) {
    if (...) {
    } else if (...) {
   } else if (...) {
   if (counter == MAX) {
      counter = 0;
 for (i = 0; i < MAX; i++) {
    if (...) {
    if (...) {
  if (...) {
  if (...) {
I somehow would need to make if anywhere in:
    if (...) {
    if (...) {
  if (...) {
  if (...) {
is detected that one button was pressed, whole program should start from the beginning. I don't know really how to accomplish that.
http://arduino.cc/en/Reference/Break
What does "whole program should start from the beginning" mean? Re-run setup and start looping again? Just return to the beginning of loop for the next pass?
Assuming you have something like:
   // initialization code
  while (...) {
      counter = 0;
If you want to detect the button press and exit loop() but continue to the next loop() call, just use the return keyword to exit loop():
  for (i = 0; i < MAX; ++i) {
    if (BUTTON_PRESSED) {
      return;
If you want to restart with setup() when a button press is detected, call it from within loop(), followed by a return:
      setup()
      return;
      setup()
Or not...
PaulS:
I meant that it should start for the the beginning of void loop.
I haven't written it but after for (i = 0; i < MAX; i++) { and before every line until the end of that for loop Arduino should detect if one button was pressed and if it was contiune from the void loop { ...
void loop {
       if (BUTTON_PRESSED != TRUE) {
              if (array[i] == 1) {
                 digitalWrite(LED3, HIGH);
                 digitalWrite(LED4, HIGH);
                 digitalWrite(LED3, LOW);
                 digitalWrite(LED4, LOW);
                 Serial.print("Executing ");
                 Serial.print(i);
                 Serial.print(" ");
                 Serial.println(array[i]);
              if (array[i] == 2) {
                 digitalWrite(LED1, HIGH);
                 digitalWrite (LED2, HIGH);
                 digitalWrite(LED1, LOW);
                 digitalWrite(LED2,LOW);
                 Serial.print("Izvrsavam ");
                 Serial.print(i);
                 Serial.print(" ");
              if (array[i] == 3) {
                 digitalWrite(LED2, HIGH);
                 digitalWrite(LED2, LOW);
                 Serial.print(i);
                 Serial.print(" ");
              if (array[i] == 4) {
                   Serial.print(i);
                   Serial.print(" ");
Can you try:
                 return;
