I am in the process of programming a fire fighting robot. I am using arduino mega, motor driver, microphone, buzzer, ultrasonic sensor, servo, flame sensor, fan module.
The issue I have now is that when the arduino detects a sound loud enough, it begins the "auto_avoidance’ loop. My question is, how do I exit that loop once the flame sensor detects the flame?
Realistically, I would like for the robot to run the auto_avoidance then when the flame is detected, the robot will stop in its tracks, turn on the fan, and then turn left and right slowly to insure that the flame is extinguished.
#include <Servo.h>
#define IN1 8 //K1、K2 motor direction
#define IN2 9 //K1、K2 motor direction
#define IN3 10 //K3、K4 motor direction
#define IN4 12 //K3、K4 motor direction
#define ENA 5 // Needs to be a PWM pin to be able to control motor speed ENA
#define ENB 6 // Needs to be a PWM pin to be able to control motor speed ENB
#define LED1 2 //left led connect to D2
#define LED2 3 //right led connect to D3
#define SERVO 11 //servo connect to D11
#define echo A3 // Ultrasonic Echo pin connect to A2
#define trig A2 // Ultrasonic Trig pin connect to A3
#define mictrigger 4 //Digital Microphone Trigger
#define buzzer 2 //buzzer connect to D2
#define RSPEED 255 //right motor speed
#define LSPEED 255 //left motor speed
#define FlameDetect 13 //flame detect pin 13
#define fanpinpos 3 //fan turn on pin 3
#define fanpinneg 7
int sensorDigitalPin = 4; // Select the Arduino input pin to accept the Sound Sensor's digital output
int digitalValue; // Define variable to store the digital value coming from the Sound Sensor
enum DN
START_AVOIDANCE,//start avoidance
STOP_AVOIDANCE,//stop avoidance
DEF
} Drive_Num = DEF;
int leftscanval, centerscanval, rightscanval, ldiagonalscanval, rdiagonalscanval;
const int distancelimit = 35; //distance limit for obstacles in front
const int sidedistancelimit = 18; //minimum distance in cm to obstacles at both sides (the car will allow a shorter distance sideways)
Servo head;
/*motor control*/
void go_ahead()//go ahead
digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
//delay(t);
void go_back() //go back
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
//delay(t);
void go_stop() //stop
void turn_left()//turn left
//delay(t);
void turn_right()//turn right
//delay(t);
/*set motor speed */
void set_motorspeed(int lspeed, int rspeed)
analogWrite(ENA, lspeed);
analogWrite(ENB, rspeed);
void buzz_on() //open buzzer
digitalWrite(buzzer, LOW);
void buzz_off() //close buzzer
digitalWrite(buzzer, HIGH);
void alarm() {
buzz_on();
delay(100);
buzz_off();
/*******control led*******/
void open_led(int led_num)
if (led_num == 1) digitalWrite(LED1, LOW);
else digitalWrite(LED2, LOW);
void close_led(char led_num)
if (led_num == 1) digitalWrite(LED1, HIGH);
else digitalWrite(LED2, HIGH);
/*detection of ultrasonic distance*/
int watch() {
long howfar;
digitalWrite(trig, LOW);
delayMicroseconds(5);
digitalWrite(trig, HIGH);
delayMicroseconds(15);
howfar = pulseIn(echo, HIGH);
howfar = howfar * 0.01657; //how far away is the object in cm
Serial.println((int)howfar);
return round(howfar);
/**************Microphone Frequency***************/
void Mic_Trig()
Serial.begin(9600); // The IDE settings for Serial Monitor/Plotter (preferred) must match this speed
pinMode(sensorDigitalPin, INPUT); // Define pin 7 as an input port, to accept digital input
// Define LED13 as an output port, to indicate digital trigger reached
digitalValue = digitalRead(sensorDigitalPin); // Read the value of the digital interface 7 assigned to digitalValue
if (digitalValue == HIGH) // When the Sound Sensor sends signal, via voltage present, light LED13 (L)
auto_avoidance();
boolean stat = digitalRead(FlameDetect);//read the value of D13
if (stat == LOW) {
go_stop();
turnonfan();
turnofffan();
void turnonfan() {
digitalWrite(fanpinpos, LOW); //turn on the fan
digitalWrite(fanpinneg, HIGH); // turn on the fan
void turnofffan() {
digitalWrite(fanpinneg, LOW);
void auto_avoidance() {
head.write(90);
delay(100);
centerscanval = watch();
if (centerscanval >= distancelimit) {
set_motorspeed(LSPEED, RSPEED);
go_ahead();
else {
go_stop();
alarm();
head.write(120);
delay(150);
ldiagonalscanval = watch();
head.write(180);
delay(150);
leftscanval = watch();
head.write(90);
delay(150);
head.write(60);
delay(150);
rdiagonalscanval = watch();
head.write(0);
delay(150);
rightscanval = watch();
head.write(90);
if (ldiagonalscanval >= sidedistancelimit && leftscanval >= sidedistancelimit) {
go_back();
delay(400);
turn_left();
delay(400);
else if (rdiagonalscanval >= sidedistancelimit && rightscanval >= sidedistancelimit) {
go_back();
delay(400);
turn_right();
delay(400);
/****L298N****/
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(ENA, OUTPUT);
pinMode(ENB, OUTPUT);
/****LED****/
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
close_led(1), close_led(2); //close led
/*init HC-SR04*/
pinMode(trig, OUTPUT);
pinMode(echo, INPUT);
/*init buzzer*/
pinMode(buzzer, OUTPUT);
buzz_off();
/*init servo*/
head.attach(SERVO);
head.write(85);
/*init fan*/
pinMode(13, INPUT);
pinMode(3, OUTPUT);
pinMode(7, OUTPUT);
Embedded_ROBOT_Code.ino (5.63 KB)
