How to exit while loop with IRRemote library
I’m trying to write some code to control a WS2812B LED strip using an IR remote using the FastLED library. I’m able to control the fill_solid and BRIGHTNESS cases properly, but I’m having trouble with the 0xFFA25D (“CH-”) case. I want it to be able to run continuously until another button is pressed, but I can’t seem to get the IR receiver to read within the while loop.
#include <IRremote.h>
#include <FastLED.h>
#define LED_PIN     8
#define NUM_LEDS    55
#define LED_TYPE    WS2812B
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
int BRIGHTNESS = 55;
const int RECV_PIN = 7;
IRrecv irrecv(RECV_PIN);
decode_results results;
unsigned long key_value = 0;
CRGBPalette16 effects[4];
int count = 0;
int hold = 1;
  irrecv.enableIRIn();
  irrecv.blink13(true);
  FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  FastLED.setBrightness(BRIGHTNESS);
  effects[0] = RainbowColors_p;
  effects[1] = RainbowStripeColors_p;
  effects[2] = CloudColors_p;
  effects[3] = PartyColors_p;
  if (irrecv.decode(&results)) {
    if (results.value == 0XFFFFFFFF)
      results.value = key_value;
    switch (results.value) {
      case 0xFFA25D:
        Serial.println("CH-");
        hold = 1;
        while (hold == 1) {
          static uint8_t startIndex = 0;
          startIndex = startIndex + 1; /* motion speed */
          FillLEDsFromPaletteColors(startIndex);
          FastLED.show();
          FastLED.delay(10);
          irrecv.resume();
          if (results.value != 0xFFA25D) {
            hold = 0;
      case 0xFF629D:
        Serial.println("CH");
      case 0xFFE21D:
        Serial.println("CH+");
      case 0xFF22DD:
        Serial.println("|<<");
      case 0xFF02FD:
        Serial.println(">>|");
        count++;
        break ;
      case 0xFFC23D:
        Serial.println(">|");
        break ;
      case 0xFFE01F:
        Serial.println("-");
        BRIGHTNESS -= 10;
        if (BRIGHTNESS < 0) {
          BRIGHTNESS = 0;
        FastLED.show();
        break ;
      case 0xFFA857:
        Serial.println("+");
        BRIGHTNESS += 10;
        if (BRIGHTNESS > 255) {
          BRIGHTNESS = 255;
        FastLED.show();
        break ;
      case 0xFF906F:
        Serial.println("EQ");
        break ;
      case 0xFF6897:
        Serial.println("0");
        fill_solid(leds, NUM_LEDS, CRGB::Black);
        FastLED.show();
        break ;
      case 0xFF9867:
        Serial.println("100+");
        break ;
      case 0xFFB04F:
        Serial.println("200+");
        break ;
      case 0xFF30CF:
        Serial.println("1");
        fill_solid(leds, NUM_LEDS, CRGB::Red);
        FastLED.show();
        break ;
      case 0xFF18E7:
        Serial.println("2");
        fill_solid(leds, NUM_LEDS, CRGB::Green);
        FastLED.show();
        break ;
      case 0xFF7A85:
        Serial.println("3");
        fill_solid(leds, NUM_LEDS, CRGB::Blue);
        FastLED.show();
        break ;
      case 0xFF10EF:
        Serial.println("4");
        fill_solid(leds, NUM_LEDS, CRGB::Magenta);
        FastLED.show();
        break ;
      case 0xFF38C7:
        Serial.println("5");
        fill_solid(leds, NUM_LEDS, CRGB::Cyan);
        FastLED.show();
        break ;
      case 0xFF5AA5:
        Serial.println("6");
        fill_solid(leds, NUM_LEDS, CRGB::Yellow);
        FastLED.show();
        break ;
      case 0xFF42BD:
        Serial.println("7");
        fill_solid(leds, NUM_LEDS, CRGB::Pink);
        FastLED.show();
        break ;
      case 0xFF4AB5:
        Serial.println("8");
        fill_solid(leds, NUM_LEDS, CRGB::Orange);
        FastLED.show();
        break ;
      case 0xFF52AD:
        Serial.println("9");
        fill_solid(leds, NUM_LEDS, CRGB::White);
        FastLED.show();
        break ;
    key_value = results.value;
    irrecv.resume();
void FillLEDsFromPaletteColors(uint8_t colorIndex)
  for ( int i = 0; i < NUM_LEDS; i++) {
    leds[i] = ColorFromPalette(effects[0], colorIndex, BRIGHTNESS, LINEARBLEND);
    colorIndex += 3;
Thank you for any help!
Don't use a while loop, use a state variable.
Get 0xFFA25D case to set the state to indicate that the FastLEDs display sequence should be active. That's all.
Get all the other selections to cancel the state.
Then all you have to do is test somewhere in loop() if the sequence is active and progress it if so.
Put the decoding code in a separate function, with a meaningful name, called from loop. The code to drive the FastLEDs should also be in a separate function, with a wisely chosen name.
Then loop will be clean and look something like:
boolean chase_active = false ;
    handle_IR(results) ;
  if (chase_active)
    handle_chase () ;
void handle_IR (decode_results & results)
  if (results.value == 0xFFA25D)
    chase_active = true ;
    return ;
void handle_chase ()
  startIndex += 1 ;
The details I leave for you, but note how each function does one thing, not a mix of different things - this greatly improves the ease of developing code.
