i am using esp32 for getting the rssi values from esp 32 using arduino IDE.'
MY CODE
#include "WiFi.h"
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0) {
Serial.println("no networks found");
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == WIFI_AUTH_OPEN)?" ":"*");
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(5000);
problem
I want to export the values of RSSI from the serial monitor into excel. I have used plx DAQ ( I found this as a frequent solution on the internet) but this does not work in my case it gives an error that port is unavailable or check your port. (I have checked COM it was correct) I tried using excel data streamer using the same arduino script but nothing appear on the sheet. the data columns were empty do I have to change the script? if yes what change? the excel sheet should have three columns TIMESTAMP,SSID(WIFI NAME), RSSI.
THANKS IN ADVANCE.
