How to export the data from serial monitor?
Hello:
I'm using Arduino Uno, and pin AO and A1 reads some voltage level and print to the serial monitor.
i'm measuring the motor while current increases, so i need the current data to draw the graph.
the problem is how can i use these data. maybe export to an excel file or something.
thanks.
The easiest way is to write the data to the Serial Monitor in CSV format like this:
123, 456
122, 444
122, 434
etc.
Then simply copy the whole serial monitor window ^a ^c
And paste it into Excel (I use Open Office) but same principal. You have to tell it to use ',' as a delimiter and there you go, a nice set of data that you can chart to your hearts content.
Or use a proper serial terminal emulator that has the option to log to file built-in.
