I am using an arduino UNO WIFI Rev.2. I am doing an experiment where I would like to extract a value of type FLOAT from a payload and store that value inside a variable that can be used else where in the program. I am not so advanced with JSON as I am still learning. How would you suggest I extract the value from the 'Value' field from the JSON doc which is getting measurements from a DHT sensor? Any help is appreciated.
#define BROKER_IP "iop.test.kamk.gv"
#define BROKER_PORT 1883
#define DEV_NAME "mqttdevice"
#define MQTT_USER ""
#define MQTT_PW ""
// WiFi settings for Visitor -
const char ssid[] = "freevisitor"; // Network SSID
const char pass[] = "123visitor"; // Password
// Library functions
#include <ArduinoJson.h> // Library ArduinoJson by Benoit Blanchon ver. 6.16.1
#include <DHT.h> // DHT sensor library by Adafruit ver. 1.3.10
#include <MQTT.h> // Library MQTT by Joel Gaehwiler ver. 2.4.7
#include <WiFiNINA.h> // Library WiFiNINA by Arduino ver. 1.7.0
WiFiClient Network; // Creates a client to the internet
MQTTClient client; // Creates MQTT client
const char topic_out[] = "KAMK/students/sensor/y"; // MQTT message topic -
const char topic_in[] = "KAMK/students/sensor/y"; // MQTT message topic
// Delay variables and settings
unsigned long currentMillis;
unsigned long lastTemperature = 0;
unsigned long lastHumidity = 0;
StaticJsonDocument<200> JsonDoc; // Reserves memory for JSON document
// DHT sensor settings
#define DHTTYPE DHT11
#define DHT11Pin 2
#define TEMPTYPE 0 // Celsius degrees
DHT dht(DHT11Pin, DHTTYPE); // Connection for the sensor
pinMode(LED_BUILTIN,OUTPUT);
WiFi.begin(ssid, pass);
client.begin(BROKER_IP, BROKER_PORT, Network);
client.onMessage(messageReceived);
connect();
dht.begin();
char AdString[200];
client.loop();
if (!client.connected())
connect();
currentMillis = millis();
if (currentMillis - lastTemperature > 6000)
lastTemperature = currentMillis;
// Blink LED to indicate message leaving
if ( digitalRead(LED_BUILTIN) )
digitalWrite(LED_BUILTIN,LOW);
digitalWrite(LED_BUILTIN,HIGH);
// Json format
JsonDoc.clear();
JsonDoc["Sensor"] = "room_1a";
JsonDoc["Type"] = "temperature";
JsonDoc["Value"] = dht.readTemperature(TEMPTYPE);
serializeJson(JsonDoc, AdString);
client.publish(topic_out, AdString); //
Serial.print("Temperature sent.");
// if (currentMillis - lastHumidity > 10000)
// lastHumidity = currentMillis;
// // Json format
// JsonDoc.clear();
// JsonDoc["Sensor"] = "room_1b";
// JsonDoc["Type"] = "humidity";
// JsonDoc["Value"] = dht.readHumidity();
// serializeJson(JsonDoc, AdString);
// client.publish(topic_out, AdString); //
// Serial.println("Humidity sent.");
void connect()
Serial.print("Checking WiFi...");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
Serial.print("\nConnecting MQTT server...");
while (!client.connect(DEV_NAME, MQTT_USER, MQTT_PW))
Serial.print(".");
Serial.println("\nConnected!");
// Creat Topic
client.subscribe(topic_in);
String messageReceived( String &topic, String &payload) //String &topic,
Serial.println("incoming: " + topic + " - " + payload);
Serial.println(payload);
return(payload);
