How to extract this number
Hi
If I have a number this way
x= 22,123456789
How to make
y= 123456789
Note that the value (y) is taken after the comma (,) .
Thank you
Have a look at the parse example in Serial Input Basics
...R
Seems easy,
while it is probably not what you wanted, or will be able to achieve on 8 bit Arduinos.
long x, y;
  Serial.begin(250000);
  x = (22,123456789);
  y = x;
  Serial.println(y);
void loop() {}
123456789
If the comma should denote a decimal point, you will need a system that really supports double
and obviously a different strategy. :wink:
#include <string.h>
#include <stdlib.h>
void(setup)
  char* x= "22,123456789";
   // Get first split
   strtok(x,",");
   char *y= strtok(NULL, ",");
   // Prints "123456789"
   Serial.println(y);
   // If you want it as a number
   long yValue = atol(y);
Have fun!
Might want to use a long int for yValue and atol() instead of this:
   Serial.println(y);
   int yValue = atoi(y);
Do you have a number or a text representation of a number?
thank you all
I really benefited from this information.
Thank you from my heart ....
Robin2:
...R
This sounds good
But in Example (5) in Serial Input Basics
// Example 5 - Receive with start- and end-markers combined with parsing
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];        // temporary array for use when parsing
     // variables to hold the parsed data
char messageFromPC[numChars] = {0};
int integerFromPC = 0;
float floatFromPC = 0.0;
boolean newData = false;
   Serial.println("This demo expects 3 pieces of data - text, an integer and a floating point value");
   Serial.println("Enter data in this style <HelloWorld, 12, 24.7>  ");
   recvWithStartEndMarkers();
   if (newData == true) {
       strcpy(tempChars, receivedChars);
           // this temporary copy is necessary to protect the original data
           //   because strtok() used in parseData() replaces the commas with \0
       parseData();
       showParsedData();
       newData = false;
void recvWithStartEndMarkers() {
   static boolean recvInProgress = false;
   static byte ndx = 0;
   char startMarker = '<';
   char endMarker = '>';
   char rc;
   while (Serial.available() > 0 && newData == false) {
       rc = Serial.read();
       if (recvInProgress == true) {
           if (rc != endMarker) {
               receivedChars[ndx] = rc;
               ndx++;
               if (ndx >= numChars) {
                   ndx = numChars - 1;
           else {
               receivedChars[ndx] = '\0'; // terminate the string
               ndx = 0;
               newData = true;
       else if (rc == startMarker) {
           recvInProgress = true;
void parseData() {      // split the data into its parts
   char * strtokIndx; // this is used by strtok() as an index
   strtokIndx = strtok(tempChars,",");      // get the first part - the string
   strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
   strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
   integerFromPC = atoi(strtokIndx);     // convert this part to an integer
   floatFromPC = atof(strtokIndx);     // convert this part to a float
void showParsedData() {
   Serial.print("x ");
   Serial.println(messageFromPC);
   Serial.print("Integer ");
   Serial.print("y ");
   Serial.println(floatFromPC);
I tried this code works great but only receives from a user
How can be controlled so that it receives from (Serial.println(G)) and analyzes them in the same way
G= <84515,5452.874>
Serial.println(G)
x= 84515
y=5452.874
I hope that the thing I want is clear .... Thank you
Did you see posts #3 and #4?
The output from Serial.println() is the number of bytes that were written to the outgoing serial buffer. Hardly useful input to a string parsing function.
Now, passing G to that function would be a completely different story.
