How to feed back 16 analog signals into an Arduino Nano
Hi!
I'm using a few I2C 4-channel DAC ICs (MCP4728) to generate 16 analog signals (signals go from 0 to 5V but are analog, not digital). Let's call them DAC[0-15].
I control these via I2C from an Arduino Nano SDA and SCL lines.
Now I would like to feed back those analog signals to the Arduino ADC ports to do an analog to digital conversion. Nano has 8 ADC lines, A[0-7], but I have 16 signals.
What IC can I use to switch between DAC[0-7] and DAC[8-15] and control it from the Arduino?
I looked into multiplexers but they handle only one line on one side of the chip (an I want to leverage the multiple ADC lines of the Nano).
Thanks in advance!
Something like an Analog Devices ADG508F analogue switch is going to be your friend. The Arduino Nano ATMEGA MCU only really has one ADC anyway, with an analog MUX in front of it. Another couple of 8:1 muxes will get you 16 inputs.
Ok thanks!
So maybe instead of leveraging all A0-7 lines I could use a CD74HC4067 (Texas Instruments) http://www.ti.com/product/cd74hc4067 to multiplex the 16 analog signals to Arduino's A0 ADC?
Best.
Yes, exactly. Thanks for the pointer to the TI MUX. I could only find 8:1 ones when I looked on Mouser.
Sure np. I'll give it a shot.
Here's someone that published a sketch if you're curious:
Best
gardner:
You can use a 4051 chip to control up to eight other 4051 chips fairly easily. Some schematics below.
https://www.google.com/search?q=4051+arduino&num=100&as_qdr=all&tbm=isch&tbo=u&source=univ&sa=X&ei=2XZAVMW9GMyQNuatgCg&ved=0CDQQsAQ&biw=1136&bih=627
Just realized that the I2C lines occupy two of the ADC pins so it wasn't possible to use the 8 ADC pins anyway!
Use a couple of SPI 8-channel ADCs then.
http://www.digikey.com/product-detail/en/MCP3208-CI%2FP/MCP3208-CI%2FP-ND/305928
I could use an external ADC, thanks.
