Iam trying to compile the example sketch HelloWorldi2c from the LiquidCrystal_I2C.h library but the compiler complains about the wire.h library.
Interestingly, there is no similar problem when I compile other sketches using wire.h
It appears that the wire.h is not found. Its probably something trivial but I am stack ![]()
Here's the output:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\John\AppData\Local\Arduino15\packages -hardware D:\Dropbox\MCU\Controller_Firmware\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\John\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Dropbox\MCU\Controller_Firmware\libraries -fqbn=MightyCore:avr:1284:bootloader=uart0,pinout=standard,variant=modelP,BOD=2v7,LTO=Os,clock=16MHz_external -vid-pid=0403_6001 -ide-version=10812 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_10386 -warnings=all -build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_99456 -prefs=build.warn_data_percentage=75 -verbose C:\Users\John\AppData\Local\Temp\arduino_modified_sketch_529893\HelloWorld_i2c.pde
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\John\AppData\Local\Arduino15\packages -hardware D:\Dropbox\MCU\Controller_Firmware\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\John\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Dropbox\MCU\Controller_Firmware\libraries -fqbn=MightyCore:avr:1284:bootloader=uart0,pinout=standard,variant=modelP,BOD=2v7,LTO=Os,clock=16MHz_external -vid-pid=0403_6001 -ide-version=10812 -build-path C:\Users\John\AppData\Local\Temp\arduino_build_10386 -warnings=all -build-cache C:\Users\John\AppData\Local\Temp\arduino_cache_99456 -prefs=build.warn_data_percentage=75 -verbose C:\Users\John\AppData\Local\Temp\arduino_modified_sketch_529893\HelloWorld_i2c.pde
Using board '1284' from platform in folder: C:\Users\John\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.0.3
Using core 'MCUdude_corefiles' from platform in folder: C:\Users\John\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.0.3
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega1284 -DARDUINO_ARCH_AVR "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\variants\\standard" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_10386\\sketch\\HelloWorld_i2c.pde.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
 -> candidates: [Wire@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega1284 -DARDUINO_ARCH_AVR "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\variants\\standard" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\libraries\\Wire\\src" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_10386\\sketch\\HelloWorld_i2c.pde.cpp" -o nul
Alternatives for LiquidCrystal_I2C.h: [LiquidCrystal_I2C]
ResolveLibrary(LiquidCrystal_I2C.h)
 -> candidates: [LiquidCrystal_I2C]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega1284 -DARDUINO_ARCH_AVR "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\variants\\standard" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\libraries\\Wire\\src" "-ID:\\Dropbox\\MCU\\Controller_Firmware\\libraries\\LiquidCrystal_I2C" "C:\\Users\\John\\AppData\\Local\\Temp\\arduino_build_10386\\sketch\\HelloWorld_i2c.pde.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega1284 -DARDUINO_ARCH_AVR "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\variants\\standard" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\libraries\\Wire\\src" "-ID:\\Dropbox\\MCU\\Controller_Firmware\\libraries\\LiquidCrystal_I2C" "C:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega1284 -DARDUINO_ARCH_AVR "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\variants\\standard" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\libraries\\Wire\\src" "-ID:\\Dropbox\\MCU\\Controller_Firmware\\libraries\\LiquidCrystal_I2C" "C:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\libraries\\Wire\\src\\utility\\twi.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega1284 -DARDUINO_ARCH_AVR "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\variants\\standard" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\libraries\\Wire\\src" "-ID:\\Dropbox\\MCU\\Controller_Firmware\\libraries\\LiquidCrystal_I2C" "D:\\Dropbox\\MCU\\Controller_Firmware\\libraries\\LiquidCrystal_I2C\\FastIO.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10812 -DARDUINO_AVR_ATmega1284 -DARDUINO_ARCH_AVR "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\cores\\MCUdude_corefiles" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\variants\\standard" "-IC:\\Users\\John\\AppData\\Local\\Arduino15\\packages\\MightyCore\\hardware\\avr\\2.0.3\\libraries\\Wire\\src" "-ID:\\Dropbox\\MCU\\Controller_Firmware\\libraries\\LiquidCrystal_I2C" "D:\\Dropbox\\MCU\\Controller_Firmware\\libraries\\LiquidCrystal_I2C\\I2CIO.cpp" -o nul
Alternatives for ../Wire/Wire.h: []
ResolveLibrary(../Wire/Wire.h)
D:\Dropbox\MCU\Controller_Firmware\libraries\LiquidCrystal_I2C\I2CIO.cpp:35:10: fatal error: ../Wire/Wire.h: No such file or directory
 -> candidates: []
#include <../Wire/Wire.h>
compilation terminated.
Using library Wire at version 1.0 in folder: C:\Users\John\AppData\Local\Arduino15\packages\MightyCore\hardware\avr\2.0.3\libraries\Wire
Using library LiquidCrystal_I2C in folder: D:\Dropbox\MCU\Controller_Firmware\libraries\LiquidCrystal_I2C (legacy)
exit status 1
Error compiling for board ATmega1284.
