How to fill an array with objects pointers ?
Hello,
I am posting here my question because I did not find any answers on the internet.
I have two classes. An environment and a container one.
In the environment, I have a queue, which is just an array of containers pointer. I fill the queue and try to read it but get an unexpected output. Here is the code
here is the test.h
#ifndef Test_h
#define Test_h
#include "Arduino.h"
class Container
  public:
    Container(String name);
    String str();
  private:
    String _name;
class Environment
  public:
    Environment();
    void readQueue();
    void addQueue(Container* container, int i);
  private:
    Container* _queue[];
#endif
here is the test.cpp
#include "Test.h"
Container::Container(String name){
  String _name = name;
String Container::str(){
  return _name;
Environment::Environment(){
  Container* _queue[4];
void Environment::readQueue(){
  for (int n=0; n<4; n++)
      Serial.println(n);
      if (_queue[n]==NULL){
        Serial.println("empty");
      }else{
        Serial.println(_queue[n]->str());
void Environment::addQueue(Container* container, int i){
  _queue[i] = container;
here is my main file
#include <Test.h>
Environment environment;
Container container("test number one");
  environment.addQueue(&container, 1);
  environment.readQueue();
  delay(100);
  Serial.println("-----------");
and here is the output I get
0
1
2
2�
3
empty
when I was expecting to get this instead
0
empty
1
test number one
2
empty
3
empty
Any ideas why?
manuK:
Any ideas why?
whoops!
Container::Container(String name) {
I am sorry, I am a beginner. But I don't get your answer. What do you mean by whoops ?
here you create a class with a String member called _name:
class Container
  public:
    String str();
  private:
    String _name;
in your constructor you create a new local variable called _name:
the local variable is destroyed when the constructor ends...
try:
  _name = name;
and assign the argument to the class member, as you probably want to do.
:wink:
Sorry my mistake. So I change the constructor to avoid create a new local variable.
But my output is weirder. Here is just an extract.
0
⸮⸮⸮Iw⸮⸮⸮⸮⸮ح⸮⸮⸮⸮⸮o⸮⸮7⸮⸮⸮⸮/⸮⸮⸮⸮⸮⸮⸮f⸮⸮⸮⸮⸮⸮_;⸮?⸮⸮M_t⸮⸮⸮⸮p⸮y^o⸮?⸮Y⸮]߫⸮⸮⸮띵/⸮ ⸮}⸮^⸮⸮յ⸮⸮⸮⸮⸮K⸮0
0
0
0
0
0
0
0
⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮9Ha⸮6#⸮Ve⸮!⸮⸮6⸮!ܭ⸮o⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
manuK:
class Container
  public:
    String str();
  private:
    String _name;
class Environment
  public:
    Environment();
    void readQueue();
  private:
  _name = name;
String Container::str() {
  return _name;
Environment::Environment() {
void Environment::readQueue() {
  for (int n = 0; n < 4; n++)
    Serial.println(n);
    if (!_queue[n]) {
void Environment::addQueue(Container* container, int i) {
Container container("test");
  environment.addQueue(&container, 0);
Ok, thank you for your patience, your code works.
But I still have a few questions :
  • What is the difference between if (!_queue[n]){ and if (_queue[n] == NULL){?
  • Why when I put all the declaration and definition in exterior h and cpp file the program is not working (previous error reappear)?
  • Also, when i put for example
in the loop function, the program is not working any more also, why?
  • And a last question, I previously developed my program (who is a kind of super thermostat for a brewery) in python, because I am more familiar with this language and it was more easy for me to write all the unit tests, what is the c++ equivalent of push and pop ? I find out with the std::queue::push() and std::queue::pop() of the queue library, but this is not implemented in arduino. What is the alternative ?
whoops again!
I thought you'd be able to find that one, since you did exactly the same error twice. ::slight_smile:
similarly, this created a 4 element array local to the constructor.
#include "Test.h"
Test.h:
#ifndef TEST_H
#define TEST_H
class Container
  public:
    String str();
  private:
    String _name;
class Environment
  public:
    Environment();
    void readQueue();
  private:
#endif
Test.cpp
#include "Test.h"
  _name = name;
  return _name;
    Serial.println(n);
    if (!_queue[n]) {
To answer your questions,
plain old C style array sizes are not mutable run-time. you can look into std::vector, but on an MCU you will have problems with dynamic allocation and your micro's limited SRAM.
manuK:
if (!_queue[n]){
and
just syntax but C++ is migrating away from NULL (#define NULL 0) for pointer comparisons.
you should use the preferred keyword nullptr
Ok I start to understand. Thank you for everything.
