Hey guys,
I want to use the Conceptinetics.h and the LiquidCrystal_I2C.h, but when I am including both of them, I get an error message.
HardwareSerial0.cpp.o (symbol from plugin): In function `Serial':
(.text+0x0): multiple definition of `__vector_25'
/tmp/359861568/build/libraries/Conceptinetics/Conceptinetics.cpp.o (symbol from plugin):(.text+0x0): first defined here
/home/ubuntu/opt/tools/avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld: Disabling relaxation: it will not work with multiple definitions
collect2: error: ld returned 1 exit status
exit status 1
I would like to delete the part of the library that isn’t working along, so how do I find out which part is the problem?
For completition, my code:
#include <Conceptinetics.h> // DMX-Module
#include <Wire.h> // Communication via SDA/SCL
#include <LiquidCrystal_I2C.h> // Communication for Display
////LC-DISPLAY//////
String version = "Ver. 0.3 alpha";
const int LCD_Adress = 0x27; //display adress (0x27)
const int LCD_Characters = 16;
const int Maxlines = 2; // Size display: 2 rows with 16 characters
LiquidCrystal_I2C lcd(LCD_Adress,LCD_Characters,Maxlines);
////MENÜ//////
int CursorLine = 0; // first character
int DisplayFirstLine = 0; // first row
char* MenuLine[] = {"1. Set DMX","2. Set Time","3. Set Mode","4. About"};
int MenuItems;
int menu=0;
////BUTTONS//////
const int Button1 = 3; // Back-Button (red)
const int Button2 = 5; // Go-Button (white)
const int Button3 = 6; // Enter-Button (green)
unsigned long lastDebounceTime1 = 0; // the last time the output pin was toggled
unsigned long debounceDelay1 = 50; // the debounce time; increase if the output flickers
int buttonState1=HIGH; // the current reading from the input pin
int lastButtonState1 = LOW; // the previous reading from the input pin
byte button1 = 0; // becomes 1 if pressed
unsigned long lastDebounceTime2 = 0;
unsigned long debounceDelay2 = 50;
unsigned long buttonCounter2 = 1000;
int buttonState2=HIGH;
int lastButtonState2 = LOW;
byte button2 = 0;
unsigned long lastDebounceTime3 = 0;
unsigned long debounceDelay3 = 50;
int buttonState3=HIGH;
int lastButtonState3 = LOW;
byte button3 = 0;
///DMX///
//int dmx=EEPROM.readInt(0);
/////////Setup//////////
void setup ()
pinMode(Button1,INPUT);
pinMode(Button2,INPUT);
pinMode(Button3,INPUT);
////LC-Display//////
lcd.init();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Loading...");
lcd.setCursor(0,1);
lcd.print(version);
delay(1500);
MenuItems = sizeof(MenuLine)/sizeof(MenuLine[0]); //Menu
lcd.clear(); // Change to menu
print_menu();
lcd.cursor_on();
lcd.blink(); // Position of cursor will blink
////DMX//////
////DEBUG//////
// Serial.begin(9600);
// end of setup
void loop (){
buttoncheck(); //main menu
if (menu==0 && button2==1){
move_down();
if (menu==0 && button3==1){
selection();
Thank you guys in advance!
