Hello everyone,
I bought a display from Midas (link to spec. I want to fire it up by using the Arduino Uno board but the display came without any breakout/shield board, so it is a bare display.
Is there any shield board to make this display compatible with Arduino? I don't have the tools to make a PCB board for this so I am looking for a ready to use connectors or shield boards to connect this display to my Arduino.
If I solve this compatibility issue, then my second question would be whether if we can use ST7789V library for the ST7789V2 controller?
on the first question, to connect the display, you need only five resistors so as not to burn it. on the second question - yes, version 2 works with the library from Adafruit
PS f you need a test sketch for verification, I have it
My question was more about how I can connect this bare display directly with the Arduino board. Most of the example from the internet for other displays were included a shield/breakout board to make the display compatible with the Arduino. I am not sure if there is a Arduino suitable connector for this display because I couldn't find one. I am fairly new to Arduino and having hard time define which pins I should use. I know that I have to use power and ground pins and also SPI pins to communicate the display but other than that do I have to use all of the display pins? I can't connect this display directly because the pinout flexi is too small for me to work. I think I need a connector compatible with Arduino first. Don't you think?
