How to fix broken lipo battery jst connector?
Imgur
  1. I think the connector is called jst-ph 2 pin female connector. Is it right?
I've tried to find it anywhere but it seems that no one sell the jst ph 2 pin connector.
Is it possible to connect the wire to this : http://core-electronics.com.au/jst-rcy-connector-male-female-set-2-pin.html
I want to connect the battery to this:
Also people said that it's hard to install the connector into the wire.
The battery is quite expensive here in Australia so I prefer to fix it.
  1. Another question. How to connect the battery (with jst 2 pin female connector) to a breadboard?
Kind of the answer to both:
https://www.adafruit.com/?q=jst&
Those wire ends look corroded (green) so you'll need to cut back to clean copper (copper or silver) before you attempt soldering new leads on
