How to fix ghosting in 3 boards of 2-digit 7-seg displays?
Hello,
I'm working on doing multiplexing between 3 boards, 2-digits, 7-segment displays.
I'm succeeded to do the multiplexing but I get some ghosting.
Any ideas?!
This is the code:
// Multiplexing 2 digit 7-segment with 74LS47
unsigned long delay_start;
unsigned long delay_current;
unsigned long delay_period=100;
void functions_init(void){
    delay_start = micros();
void multitasking_manager(void)
    display_set_traffic_system();
    display_refresh_traffic_system();
void display_set_traffic_system(void){
    counter1 = 10;
    counter2 = 20;
    counter3 = 70;
    tens1 = counter1 / 10;
    units1 = counter1 % 10;
    tens2 = counter2 / 10;
    units2 = counter2 % 10;
    tens3 = counter3 / 10;
    units3 = counter3 % 10;
void display_refresh_traffic_system(void){
  /////////////////////////////////////////////////////////////////// 1
  delay_current = micros();
  if(delay_current - delay_start >= delay_period){
    IOEXP8_WRITE(0xFE);
    PORTB = (units1%10);
    IOEXP8_WRITE(0xFD);
    PORTB = (tens1%10);
  /////////////////////////////////////////////////////////////////// 2
    IOEXP8_WRITE(0xFB);
    PORTB = (units2%10);
    IOEXP8_WRITE(0xF7);
    PORTB = (tens2%10);
  /////////////////////////////////////////////////////////////////// 3
    IOEXP8_WRITE(0xEF);
    PORTB = (units3%10);
    IOEXP8_WRITE(0xDF);
    PORTB = (tens3%10);
It looks like the 'magic numbers' are enabling the various digits. You might try something like turning all digits off before you enable a new one.
Don
floresta: It looks like the 'magic numbers' are enabling the various digits. You might try something like turning all digits off before you enable a new one.
Don
Tried this one, but still not working perfectly.
  ioexp8_write(0xFF);
    ioexp8_write(0xFE);
  ioexp8_write(0xFF);
    ioexp8_write(0xFD);
    PORTB = (tens1%10);
  ioexp8_write(0xFF);
    ioexp8_write(0xFB);
  ioexp8_write(0xFF);
    ioexp8_write(0xF7);
    PORTB = (tens2%10);
  ioexp8_write(0xFF);
    ioexp8_write(0xEF);
  ioexp8_write(0xFF);
    ioexp8_write(0xDF);
    PORTB = (tens3%10);
Why don't you check for ideas in the LEDs and Multiplexing section of the forum.
Make sure you reference this thread so you don't get criticized for cross-posting.
Don
floresta: Why don't you check for ideas in the LEDs and Multiplexing section of the forum.
Don
How? Do you mean that I have to ask in other posts or comment in them?
Are you calling display_refresh_traffic_system() from loop? At a minimum, these calls:
“ioexp8_write(0xFF);”
Needs to be inside the if statements when the time expires, not outside since it is unconditionally called 4 times for every invocation of display_refresh_traffic_system(). I also think you need some additional code to know which digit position is currently active and just one timer test, not four.
WattsThat: Are you calling display_refresh_traffic_system() from loop?
Yes
At a minimum, these calls: “ioexp8_write(0xFF);”
Tried this one
    ioexp8_write(0xFF);
    ioexp8_write(0xFE);
    ioexp8_write(0xFF);
    ioexp8_write(0xFD);
    PORTB = (tens1%10);
    ioexp8_write(0xFF);
    ioexp8_write(0xFB);
    ioexp8_write(0xFF);
    ioexp8_write(0xF7);
    PORTB = (tens2%10);
    ioexp8_write(0xFF);
    ioexp8_write(0xEF);
    ioexp8_write(0xFF);
    ioexp8_write(0xDF);
    PORTB = (tens3%10);
And this:
    if((delay_current - delay_start >= delay_period) && digit_switch==0){
        ioexp8_write(0xFF);
        ioexp8_write(0xFE);
        ioexp8_write(0xFF);
        ioexp8_write(0xFD);
        PORTB = (tens1%10);
        digit_switch=1;
    if((delay_current - delay_start >= delay_period) && digit_switch==1){
        ioexp8_write(0xFF);
        ioexp8_write(0xFB);
        ioexp8_write(0xFF);
        ioexp8_write(0xF7);
        PORTB = (tens2%10);
        digit_switch=2;
    if((delay_current - delay_start >= delay_period) && digit_switch==2){
        ioexp8_write(0xFF);
        ioexp8_write(0xEF);
        ioexp8_write(0xFF);
        ioexp8_write(0xDF);
        PORTB = (tens2%10);
        digit_switch=0;
OK, I was able to minimize the ghosting with this one:
    if((delay_current - delay_start >= delay_period) && digit_switch == 0){
        ioexp8_write(0xFF);
        ioexp8_write(0xFE);
        digit_switch = 1;
    if((delay_current - delay_start >= delay_period) && digit_switch == 1){
        ioexp8_write(0xFF);
        ioexp8_write(0xFD);
        PORTB = (tens1%10);
        digit_switch = 2;
    if((delay_current - delay_start >= delay_period) && digit_switch == 2){
        ioexp8_write(0xFF);
        ioexp8_write(0xFB);
        digit_switch = 3;
    if((delay_current - delay_start >= delay_period) && digit_switch == 3){
        ioexp8_write(0xFF);
        ioexp8_write(0xF7);
        PORTB = (tens2%10);
        digit_switch = 4;
    if((delay_current - delay_start >= delay_period) && digit_switch == 4){
        ioexp8_write(0xFF);
        ioexp8_write(0xEF);
        digit_switch = 5;
    if((delay_current - delay_start >= delay_period) && digit_switch == 5){
        ioexp8_write(0xFF);
        ioexp8_write(0xDF);
        PORTB = (tens3%10);
        digit_switch=0;
This one was like 80-90% ghosting free, not perfect!
        ioexp8_write(0xFE);
        digit_switch = 1;
        ioexp8_write(0xFF);
        digit_switch = 2;
        ioexp8_write(0xFD);
        PORTB = (tens1%10);
        digit_switch = 3;
        ioexp8_write(0xFF);
        digit_switch = 4;
        ioexp8_write(0xFB);
        digit_switch = 5;
        ioexp8_write(0xFF);
        digit_switch = 6;
    if((delay_current - delay_start >= delay_period) && digit_switch == 6){
        ioexp8_write(0xF7);
        PORTB = (tens2%10);
        digit_switch = 7;
    if((delay_current - delay_start >= delay_period) && digit_switch == 7){
        ioexp8_write(0xFF);
        digit_switch = 8;
    if((delay_current - delay_start >= delay_period) && digit_switch == 8){
        ioexp8_write(0xEF);
        digit_switch = 9;
    if((delay_current - delay_start >= delay_period) && digit_switch == 9){
        ioexp8_write(0xFF);
        digit_switch = 10;
    if((delay_current - delay_start >= delay_period) && digit_switch == 10){
        ioexp8_write(0xDF);
        PORTB = (tens3%10);
        digit_switch = 11;
    if((delay_current - delay_start >= delay_period) && digit_switch == 11){
        ioexp8_write(0xFF);
        digit_switch = 0;
Your >= compares need to be less than for the way you’re switching digits.
You can drop the multiple “delay_current = micros()” and set once at the top of the subroutine. This assumes you’re using a reasonable delay time (> 100 micro seconds). Too small a delay value will cause brightness variations due to loop() timing variations.
This one was %90 ghosting free, still not perfect! But better, shorter and more compact.
        ioexp8_write(0xFF);     // turn all digits off
        PORTB = (units1%10);    // upload data to portb
        ioexp8_write(0xFE);     // enable board1 - digit1
        PORTB = (tens1%10);     // upload data to portb
        ioexp8_write(0xFD);     // enable board1 - digit2
        ioexp8_write(0xFF);
        ioexp8_write(0xFB);     // enable board2 - digit1
        ioexp8_write(0xFF);
        PORTB = (tens2%10);
        ioexp8_write(0xF7);     // enable board2 - digit2
        ioexp8_write(0xFF);
        ioexp8_write(0xEF);     // enable board3 - digit1
        ioexp8_write(0xFF);
        PORTB = (tens3%10);
        ioexp8_write(0xDF);     // enable board3 - digit2
Then I removed the delay and it was the same result! How about that?
        ioexp8_write(0xFF);
        ioexp8_write(0xFF);
        PORTB = (tens2%10);
        ioexp8_write(0xFF);
        ioexp8_write(0xFF);
        PORTB = (tens3%10);
While I give you karma for persistence, I have to assume you do not understand how display multiplexing works. The rough outline:
Turn off display
Set segment pattern in digit 1
Turn on the digit
Leave it on for a fixed period of time
Turn off display
Set segment pattern in digit 2
Turn on the digit
Here it is extended to a 4 digit display on an Uno displaying a fixed string of "1234". Assume a common anode display where the four anodes are on PORTB and the cathodes are on PORTD.
  DDRD = 0xff;
  DDRB = 0x0f;
  PORTB = 0xff;   // all off
  PORTD = 0x99;   // #1 in LED segments
  PORTB = 0xff-1; // turn on digit 1
  delayMicroseconds(100);    // and leave it on for a time
  PORTD = 0xb0;   // #2 in LED segments
  PORTB = 0xff-2; // turn on digit 2
  PORTD = 0xa4;   // #3 in LED segments
  PORTB = 0xff-4; // turn on digit 3
  PORTD = 0xf9;   // #4 in LED segments
  PORTB = 0xff-8; // turn on digit 4
WattsThat: While I give you karma for persistence, I have to assume you do not understand how display multiplexing works.
That was pretty clear from the start, and why I did not buy into it (apart from not having too much time to spare).
But I have been thinking all the time - what is this "delayMicroseconds(100);" business? Considering you only need to refresh the whole display about fifty times per second, 1 ms would be way more than short enough and 5 ms for each of four digits or 3 ms for six would fulfil the criterion perfectly.
Okay, so my example was a blocking program. Now that I’ve had a few minutes in front of a real computer, here it is as a non-blocking version.
const unsigned long onTime = 100UL;
unsigned long startTime;
byte dataTable[] = {0x99, 0xB0, 0xA4, 0xF9};
  DDRD = 0xff;    // port D all outputs
  DDRB = 0x0f;    // port B bottom four bits are outputs
  displayNow();
void displayNow() {
  static byte digit;
  if (micros() - startTime > onTime) {
    if ( digit > 3)
      digit = 0;
    PORTB = B1111;
    PORTD = dataTable[digit];
    PORTB = ~(1 << digit);
    digit = digit + 1;
    startTime = micros();
