So... i made a joystick but it dosen't work in games like fs22... it raises the loader and can't lower it again..
//Arduino Joystick 2.0 Library, by MHeironimus (https://github.com/MHeironimus)
//Beginners Guide, by Daniel Cantore
//Example Code (Oct 2020), with in-depth commenting
//Initial Definitions and Setup
//Libary Inclusion
#include <Joystick.h>
//Define and Allocate Input Pins to memorable names
#define joyX A0
#define joyZ A1
#define joyRY A3
#define joyButton1 2
//Initializing Axis as Integers, at a 0 default value
int zAxis_ = 0;
int RxAxis_ = 0;
int RyAxis_ = 0;
//Setting up Buttons
//Updating a static variable gives greater stability than reading directly from the digital pin.
//Giving Default Values to the Buttons for later use
int lastButton1State = 0;
//Defining the Joystick
//The Joystick is defined in the following setup:
//Joystick(Joystick HID ID, Joystick Type, Button Count, Hat Switch Count, Include X, Include Y, Include Z, Include Rx, Include Ry, Include Rz, Include Rudder, Include Throttle, Include Accelerator, Include Brake, Include Steering
//Joystick HID ID: A Hex value identifier for HID Device Recognition (default: 0x03). DO NOT USE 0x01 or 0x02
//Joystick type: Define the type of joystick from the types supported. Types: DEFAULT Joystick (0x04 or JOYSTICK_TYPE_JOYSTICK), Gamepad (0x05 or JOYSTICK_TYPE_GAMEPAD), Multi-Axis Controller (0x08 or JOYSTICK_TYPE_MULTI_AXIS)
//Button Count: Number of Buttons shown to HID system (default: 32)
//Hat Switch Count: Number of Hat Switches, max 2. (default:2)
//Include X Axis: Determines whether the X axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Y Axis: Determines whether the Y axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Z Axis: Determines whether the Z axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Rx Axis: Determines whether the X Rotational axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Ry Axis: Determines whether the Y Rotational axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Rz Axis: Determines whether the Z Rotational axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Rudder: Determines whether a Rudder axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Throttle: Determines whether a Throttle axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Accelerator: Determines whether an Accelerator axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Brake: Determines whether a Brake axis is avalible for used by the HID system, defined as a bool value (default:true)
//Include Steering: Determines whether a Steering axis is avalible for used by the HID system, defined as a bool value (default:true)
Joystick_ Joystick(0x15, JOYSTICK_TYPE_JOYSTICK, 1, 0,false,false,true,true,true,false,false,false,false,false,false);
//Set Auto Send State
//Enables Auto Sending, allowing the controller to send information to the HID system, rather than waiting to be asked.
const bool initAutoSendState = true;
//Initialize Buttons
//Buttons set up between Digital Pin and Ground, following pin allocations from earlier on
pinMode(joyButton1, INPUT_PULLUP);
//Start Joystick - Needed to start the Joystick function libary
Joystick.begin();
//Axis Reading during Runtime
//Setting Read functions for each axis and parsing correctly. The X axis will be used as an example for explanation
RxAxis_ = analogRead(A0);
RxAxis_ = map(RxAxis_,0, 1023, 0, 255);
Joystick.setRxAxis(RxAxis_);
zAxis_ = analogRead(A1);
zAxis_ = map(zAxis_,0, 1023, 0, 255);
Joystick.setZAxis(zAxis_);
RyAxis_ = analogRead(A3);
RyAxis_ = map(RyAxis_,0, 1023, 0, 255);
Joystick.setRyAxis(RyAxis_);
//Button Reading during Runtime
//Setting Read functions for each button, using a state value for memory. Button 1 will be used as an example for explanation
//Reading the current Button digital pin to the Current Button State for processing
int currentButton1State = !digitalRead(joyButton1);
//If loop - Check that the button has actually changed.
if (currentButton1State != lastButton1State){
//If the button has changed, set the specified HID button to the Current Button State
Joystick.setButton(0, currentButton1State);
//Update the Stored Button State
lastButton1State = currentButton1State;
//Pole Delay/Debounce
//To reduce unessecary processing, the frequency of the reading loop is delayed. The value(in ms) can be changed to match requirement
delay(10);
Yes i edited some of the code to make it right aaaaand it kinda works in windows but not games..
4 axis joystick with 1 button shorturl.at/jABMX
when i try to calibrate it it flickering on the blue bar... and
Z axis default -24696 min -16432 max -32767
X Axis default -25144 min -16432 max -32767
Y rotation default -25134 min -16432 max -32767
