How to fix my data reading value Temperature, Humidity and AC temp in OLED
my project is [Automatic AC Temperature Controller using Arduino, DHT11 and IR Blaster]. The problem is my Temperature, humidity have negative value and cant reading the temperature AC. How to fix this problem. Im new to arduino. Please Help.
My Code project
 * Automatic AC Temperature control using Arduino and TSOP
 * Code by: Aswinth Raj B
 * Dated: 25-10-2017
 * Website: www.circuitdigest.com
       S.No: Component Pin Arduino Pin
    1 OLED – Vcc  5V
    2 OLED – Gnd  Gnd
    3 OLED- SCK, D0,SCL,CLK 4
    4 OLED- SDA, D1,MOSI, Data  3
    5 OLED- RES, RST,RESET  7
    6 OLED- DC, A0  5
    7 OLED- CS, Chip Select 6
    8 DHT11 – Vcc 5V
    9 DHT11 – Gnd Gnd
    10  DHT11 – Signal  13
    11  TSOP – Vcc  5V
    12  TSOP – Gnd  Gnd
    13  IR Led – Anode  9
    14  IR Led – Cathode  Gnd
#include <IRremote.h> //Lib for IT Blaster and TSOP
#include <SPI.h> // Inbuilt Lib
#include <Wire.h> //Inbuilt Lib
#include <Adafruit_GFX.h> //Lib for OLED
#include <Adafruit_SSD1306.h> //Lib for OLED
#include <dht.h> //Library for dht11 Temperature and Humidity sensor (Download from Link in article)
 // Assign pins for OLED (Software config.)
#define OLED_MOSI  3
#define OLED_CLK   4
#define OLED_DC    5
#define OLED_CS    6
#define OLED_RESET 7
Adafruit_SSD1306 display(OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
#define SSD1306_LCDHEIGHT 64 //Change if you are using a Different OLED
#define DHT11_PIN 13 //Sensor output pin is connected to pin 13
dht DHT; //Sensor object named as DHT
#define Desired_temperature 27 //The desired temperature is 27*C at any time
//Decoded Remote Signals For my AC ##CHANGE IT FOR YOUR REMOTE
unsigned int ACoff[] = {4600,2500, 400,400, 350,950, 350,950, 350,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 300,450, 300,1000, 350,400, 300,450, 300,450, 300,400, 350,1000, 300,400, 350,400, 350,950, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 350,950, 350,400, 300,1000, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,450, 300,1000, 300,1000, 350};
unsigned int ACon[] = {4600,2500, 400,400, 300,1000, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,450, 300,1000, 350,400, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,950, 350,950, 350,450, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,900, 400,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 300,450, 300,1000, 350,400, 300,450, 300,1000, 300,1000, 350};
unsigned int Temp23[] = {4600,2500, 400,400, 350,950, 350,1000, 300,400, 350,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,400, 350,400, 300,450, 300,450, 300,400, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 350,400, 300,1000, 350,950, 350};
unsigned int Temp24[] = {4550,2550, 350,450, 300,1000, 300,1000, 350,400, 350,950, 350,400, 350,400, 300,450, 300,450, 300,1000, 300,450, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,400, 350,950, 350,400, 300,1000, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 300,450, 300,450, 300,1000, 300,450, 300,400, 350,1000, 300,1000, 350,400, 300,450, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,1000, 300};
unsigned int Temp25[] = {4550,2550, 400,400, 300,1000, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,450, 300,1000, 350,400, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 350,400, 300,1000, 300,1000, 350};
unsigned int Temp26[] = {4550,2550, 400,400, 300,1000, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,400, 350,1000, 300,450, 300,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 350,400, 300,1000, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 350,950, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,450, 300,1000, 300,1000, 350};
unsigned int Temp27[] = {4600,2500, 350,450, 300,1000, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 350,400, 300,1000, 300,450, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 300,450, 300,1000, 350,950, 350};
unsigned int Temp28[] = {4550,2550, 350,450, 300,1000, 300,1000, 350,400, 300,1000, 350,400, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,950, 350,400, 350,950, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 350,400, 300,1000, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 300,1000, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,450, 300,1000, 300,1000, 300};
unsigned int Temp29[] = {4550,2550, 350,400, 350,1000, 300,1000, 300,450, 300,1000, 350,400, 350,400, 300,450, 300,400, 350,1000, 300,400, 350,400, 350,950, 350,400, 350,400, 350,400, 350,950, 350,950, 350,1000, 300,400, 350,1000, 300,450, 300,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,1000, 300,400, 350,400, 350,400, 350,950, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 350,400, 300,1000, 300,1000, 350};
unsigned int Temp30[] = {4600,2500, 400,400, 350,1000, 300,1000, 300,450, 300,1000, 300,450, 300,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,950, 350,950, 350,400, 350,1000, 300,400, 350,1000, 300,400, 350,1000, 300,400, 350,400, 350,400, 350,400, 350,950, 350,400, 350,400, 350,950, 350,950, 350,400, 350,400, 350,400, 300,1000, 350,400, 300,1000, 350,400, 350,400, 300,450, 300,1000, 300,450, 300,450, 300,1000, 300,1000, 350};
//Change it for your remote
IRsend irsend;
int Measured_temp;
int Measured_Humi;
int AC_Temp;
char temp_error = 2;
int Pev_value;
boolean AC = false;
int khz = 38; // 38kHz carrier frequency for the NEC protocol
display.begin(SSD1306_SWITCHCAPVCC);
display.clearDisplay();
  DHT.read11(DHT11_PIN); //Read the Temp and Humidity
  Measured_temp = DHT.temperature + temp_error;
  Measured_Humi = DHT.humidity;
// text display tests
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
  display.print("Temperature: "); display.print(Measured_temp);display.println("C");
  display.setCursor(0,10);
  display.print("Humidity: "); display.print(Measured_Humi);display.println("%");
  display.setCursor(0,20);
  display.print("AC Temp: "); display.print(AC_Temp);display.println("C");
  display.display();
 if ((Measured_temp <= (Desired_temperature-3)) && AC == true) //If AC is turned on and temperature is less than 3 degree of Desired value #24 turn off
  irsend.sendRaw(ACoff, sizeof(ACoff) / sizeof(ACoff[0]), khz);  delay(2000);//Send signal to Turn Off the AC
  AC_Temp = 0; AC=false;
 if ((Measured_temp >= Desired_temperature+4) && AC == false) //If AC is off and measured Temp is greater than Desired Temp
  irsend.sendRaw(ACon, sizeof(ACon) / sizeof(ACon[0]), khz); delay(2000); //Send Signal to Turn On the AC
  delay(2000);
  irsend.sendRaw(Temp27, sizeof(Temp27) / sizeof(Temp27[0]), khz); //Send signal to set 27*C
  AC_Temp = 27; AC=true;
if ( Measured_temp != Pev_value) //Change the temperature only if the measured voltage value changes
if (Measured_temp == Desired_temperature+3) //If AC is ON and measured temp is very very high than desired
   irsend.sendRaw(Temp24, sizeof(Temp24) / sizeof(Temp24[0]), khz); delay(2000);//Send signal to set 24*C
  AC_Temp = 24;
if (Measured_temp == Desired_temperature+2) //If AC is ON and measured temp is very high than desired
   irsend.sendRaw(Temp25, sizeof(Temp25) / sizeof(Temp25[0]), khz); delay(2000);//Send signal to set 25*C
  AC_Temp = 25;
if (Measured_temp == Desired_temperature+1) //If AC is ON and measured temp is very high than desired
   irsend.sendRaw(Temp26, sizeof(Temp26) / sizeof(Temp26[0]), khz); delay(2000);//Send signal to set 26*C
  AC_Temp = 26;
if (Measured_temp == 27 ) //If AC is ON and measured temp is desired value
  AC_Temp = 27;
if (Measured_temp == Desired_temperature-1) //If AC is ON and measured temp is low than desired value
  irsend.sendRaw(Temp28, sizeof(Temp28) / sizeof(Temp28[0]), khz); delay(2000);//Send signal to set 28*C
  AC_Temp = 28;
if (Measured_temp == Desired_temperature-2 ) //If AC is ON and measured temp is very low than desired value
  irsend.sendRaw(Temp29, sizeof(Temp29) / sizeof(Temp29[0]), khz); delay(2000);//Send signal to set 29*C
  AC_Temp = 29;
if (Measured_temp == Desired_temperature-3 ) //If AC is ON and measured temp is very very low desired value
  irsend.sendRaw(Temp30, sizeof(Temp30) / sizeof(Temp30[0]), khz); delay(2000);//Send signal to set 30*C
  AC_Temp = 30;
Pev_value = Measured_temp;
if this problem is due to route circuit please tell me or may be due to loose connection
1 OLED – Vcc 5V
2 OLED – Gnd Gnd
6 OLED- DC, A0 5
8 DHT11 – Vcc 5V
9 DHT11 – Gnd Gnd
11 TSOP – Vcc 5V
12 TSOP – Gnd Gnd
13 IR Led – Anode 9
Hello
Run seperate tutorials to check the sensors.
