hi all...how to solved my library and board manager blank windows??
thx b4
@pert .
This may be more your area.
Hi @alhadied I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
icon on the post composer toolbar. This will add the forum's code block markup (```
) to your reply to make sure the error messages are correctly formatted.Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
at com.sun.java.swing.plaf.windows.XPStyle.getTypeEnumName(XPStyle.java:155)
at com.sun.java.swing.plaf.windows.XPStyle.getBorder(XPStyle.java:275)
at com.sun.java.swing.plaf.windows.WindowsLookAndFeel$XPBorderValue.getXPValue(WindowsLookAndFeel.java:2403)
at com.sun.java.swing.plaf.windows.WindowsLookAndFeel$XPValue.createValue(WindowsLookAndFeel.java:2357)
at javax.swing.UIDefaults.getFromHashtable(UIDefaults.java:231)
at javax.swing.UIDefaults.get(UIDefaults.java:161)
at javax.swing.MultiUIDefaults.get(MultiUIDefaults.java:64)
at javax.swing.UIDefaults.getBorder(UIDefaults.java:480)
at javax.swing.UIManager.getBorder(UIManager.java:759)
at javax.swing.border.TitledBorder.getBorder(TitledBorder.java:416)
at javax.swing.border.TitledBorder.getBorderInsets(TitledBorder.java:349)
at javax.swing.border.AbstractBorder.getBorderInsets(AbstractBorder.java:75)
at javax.swing.JComponent.getInsets(JComponent.java:1826)
at javax.swing.BoxLayout.preferredLayoutSize(BoxLayout.java:305)
at java.awt.Container.preferredSize(Container.java:1799)
at java.awt.Container.getPreferredSize(Container.java:1783)
at javax.swing.JComponent.getPreferredSize(JComponent.java:1664)
at cc.arduino.contributions.libraries.ui.ContributedLibraryTableCellRenderer.getTableCellRendererComponent(ContributedLibraryTableCellRenderer.java:56)
at javax.swing.JTable.prepareRenderer(JTable.java:5729)
at javax.swing.plaf.basic.BasicTableUI.paintCell(BasicTableUI.java:2114)
at javax.swing.plaf.basic.BasicTableUI.paintCells(BasicTableUI.java:2016)
at javax.swing.plaf.basic.BasicTableUI.paint(BasicTableUI.java:1812)
at javax.swing.plaf.ComponentUI.update(ComponentUI.java:161)
at javax.swing.JComponent.paintComponent(JComponent.java:780)
at javax.swing.JComponent.paint(JComponent.java:1056)
at javax.swing.JComponent.paintChildren(JComponent.java:889)
at javax.swing.JComponent.paint(JComponent.java:1065)
at javax.swing.JViewport.paint(JViewport.java:728)
at javax.swing.JLayeredPane.paint(JLayeredPane.java:586)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5217)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1579)
at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1502)
at javax.swing.RepaintManager.paint(RepaintManager.java:1272)
at javax.swing.JComponent.paint(JComponent.java:1042)
at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:39)
at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:79)
at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:116)
at java.awt.Container.paint(Container.java:1978)
at java.awt.Window.paint(Window.java:3906)
at javax.swing.RepaintManager$4.run(RepaintManager.java:842)
at javax.swing.RepaintManager$4.run(RepaintManager.java:814)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789)
at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738)
at javax.swing.RepaintManager.access$1200(RepaintManager.java:64)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:109)
at java.awt.WaitDispatchSupport$2.run(WaitDispatchSupport.java:190)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:235)
at java.awt.WaitDispatchSupport$4.run(WaitDispatchSupport.java:233)
at java.awt.WaitDispatchSupport.enter(WaitDispatchSupport.java:233)
at java.awt.Dialog.show(Dialog.java:1084)
at java.awt.Component.show(Component.java:1671)
at java.awt.Component.setVisible(Component.java:1623)
at java.awt.Window.setVisible(Window.java:1014)
at java.awt.Dialog.setVisible(Dialog.java:1005)
at processing.app.Base.openLibraryManager(Base.java:1391)
at processing.app.Base.lambda$rebuildImportMenu$2(Base.java:1116)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:842)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:886)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
at javax.swing.BoxLayout.layoutContainer(BoxLayout.java:413)
at java.awt.Container.layout(Container.java:1513)
at java.awt.Container.doLayout(Container.java:1502)
at java.awt.Container.validateTree(Container.java:1698)
at java.awt.Container.validate(Container.java:1633)
at javax.swing.JTable.editCellAt(JTable.java:3525)
at javax.swing.JTable.editCellAt(JTable.java:3476)
at cc.arduino.contributions.ui.InstallerJDialog$4.mouseMoved(InstallerJDialog.java:207)
at java.awt.AWTEventMulticaster.mouseMoved(AWTEventMulticaster.java:330)
at java.awt.AWTEventMulticaster.mouseMoved(AWTEventMulticaster.java:329)
at java.awt.Component.processMouseMotionEvent(Component.java:6584)
at javax.swing.JComponent.processMouseMotionEvent(JComponent.java:3342)
at java.awt.Component.processEvent(Component.java:6308)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4548)
at java.awt.Container.validateTree(Container.java:1707)
at javax.swing.RepaintManager$3.run(RepaintManager.java:711)
at javax.swing.RepaintManager$3.run(RepaintManager.java:709)
at javax.swing.RepaintManager.validateInvalidComponents(RepaintManager.java:708)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1731)
at javax.swing.JViewport.validateView(JViewport.java:482)
at javax.swing.JViewport.scrollRectToVisible(JViewport.java:393)
at javax.swing.JComponent.scrollRectToVisible(JComponent.java:3111)
at javax.swing.text.DefaultCaret.adjustVisibility(DefaultCaret.java:285)
at javax.swing.text.DefaultCaret.repaintNewCaret(DefaultCaret.java:1313)
at javax.swing.text.DefaultCaret$1.run(DefaultCaret.java:1287)
at javax.swing.JComponent.paintToOffscreen(JComponent.java:5210)
at javax.swing.JComponent._paintImmediately(JComponent.java:5158)
at javax.swing.JComponent.paintImmediately(JComponent.java:4969)
at javax.swing.RepaintManager$4.run(RepaintManager.java:831)
at javax.swing.JTable.getToolTipText(JTable.java:3394)
at javax.swing.ToolTipManager$insideTimerAction.actionPerformed(ToolTipManager.java:663)
at javax.swing.Timer.fireActionPerformed(Timer.java:313)
at javax.swing.Timer$DoPostEvent.run(Timer.java:245)
@Ballscrewbob
@pert
problem solved...just setting on my windows theme to default.thx 4 help
I'm glad to hear you got it working. Thanks for taking the time to post an update with your solution.
Regards, Per
Yeah bro...i hope may be next update arduino ide team can fix this isues immediately.thx
It might be already. Have you tried Arduino IDE 2.0.0-beta.7?
Installed.Nice interface...and worked fine with my custom windows theme.Like it Thx 4 info bro.
Regard Alhadied
Way cool! Thanks for the update.
