How to Fix this code:exit status 1 'isOnePressed' was not declared in this scope
This code use for open two magnetic door and 1 led on/off using Arduino UNO and 1Sheeld(Keypad Shield)
#define CUSTOM_SETTINGS
#define INCLUDE_KEYPAD_SHIELD
/* Include 1Sheeld library. */
#include <OneSheeld.h>
/* Define an iterator. */
int iterations = 0;
/* A name for the LockPin on pin D2. */
int lockPin1 = 2;
int ledRed1 = A5;
int ledGreen1 = A4;
/* A name for the LockPin on pin D3. */
int lockPin2 = 3;
int ledRed2 = A3;
int ledGreen2 = A2;
/* A name for the SwitchPin on pin D5. and LED on pin A0*/
int SuisPinA = 5;
int ledlampuA = A0;
 /* Start communication. */
 OneSheeld.begin();
 /* Set the LED & LOCK as output. */
 pinMode(lockPin1, OUTPUT);
 pinMode(ledRed1, OUTPUT);
 pinMode(ledGreen1, OUTPUT);
 pinMode(lockPin2, OUTPUT);
 pinMode(ledRed2, OUTPUT);
 pinMode(ledGreen2, OUTPUT);
 /* Set the SuisPin pin as output. */
 pinMode(SuisPinA, INPUT);
 /* Set the LED pin as output. */
 pinMode(ledlampuA, OUTPUT);
   //======LED=======
   /* If keypad's button A is pressed. */
   if (Keypad.isRowPressed(0) && Keypad.isColumnPressed(3))
     /* Turn on the LED A. */
     digitalWrite(ledlampuA, HIGH);
   /* If keypad's button D is pressed. */
   else if (Keypad.isRowPressed(3) && Keypad.isColumnPressed(3))
     digitalWrite(ledlampuA, LOW);
 //======Front Door=======
   /* Check if "1" is pressed, iterate one time. */
   if (iterations == 0 && isOnePressed())
     iterations++;
   /* Check if "2" is pressed, iterate one time. */
   else if (iterations == 1 && isTwoPressed())
     iterations++;
   /* Check if "3" is pressed, iterate one time. */
   else if (iterations == 2 && isThreePressed())
     iterations++;
   /* Check if "4" is pressed, iterate one time. */
   else if (iterations == 3 && isFourPressed())
     iterations++;
   /* Check if any other button is pressed, reset iterations. */
   else if (isOtherButtonPressed())
     iterations = 0;
   /* Check if the number of iterations is 4. */
   if (iterations == 4)
     digitalWrite(lockPin1, LOW);
     digitalWrite(ledGreen1, HIGH);
     digitalWrite(ledRed1, LOW);
     OneSheeld.delay(6000);
     digitalWrite(lockPin1, HIGH);
     digitalWrite(ledRed1, HIGH);
     digitalWrite(ledGreen1, LOW);
     OneSheeld.delay(1000);
     /* Reset the iterator. */
     iterations = 0;
 //======Garage Door=======
   /* Check if "5" is pressed, iterate one time. */
   if (iterations == 5 && isFivePressed())
     iterations++;
   /* Check if "6" is pressed, iterate one time. */
   else if (iterations == 6 && isSixPressed())
     iterations++;
   /* Check if "7" is pressed, iterate one time. */
   else if (iterations == 7 && isSevenPressed())
     iterations++;
   /* Check if "8" is pressed, iterate one time. */
   else if (iterations == 8 && isEightPressed())
     iterations++;
     iterations = 0;
     digitalWrite(lockPin2, LOW);
     digitalWrite(ledGreen2, HIGH);
     digitalWrite(ledRed2, LOW);
     digitalWrite(lockPin2, HIGH);
     digitalWrite(ledRed2, HIGH);
     digitalWrite(ledGreen2, LOW);
     iterations = 0;
 /* Helper functions check if a certain button is pressed by checking its row and column. */
 boolean isOnePressed() {
   return Keypad.isRowPressed(0) && Keypad.isColumnPressed(0);
 boolean isTwoPressed() {
   return Keypad.isRowPressed(0) && Keypad.isColumnPressed(1);
 boolean isThreePressed() {
   return Keypad.isRowPressed(0) && Keypad.isColumnPressed(2);
 boolean isFourPressed() {
   return Keypad.isRowPressed(1) && Keypad.isColumnPressed(0);
 boolean isFivePressed() {
 boolean isSixPressed() {
 boolean isSevenPressed() {
 boolean isEightPressed() {
 boolean isOtherButtonPressed() {
   return ((Keypad.isAnyColumnPressed() || Keypad.isAnyColumnPressed()) && !isOnePressed() && !isTwoPressed() && !isThreePressed() && !isFourPressed());
{ <------<<<< Why
Get rid of them.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
Thank you for the tips
Where does the loop() function end in your program ?
