How to format data to serial monitor? excessive spacing
It's going to be like a data logger but it will be 512k in size total with no formatting or spacing. I am trying to dump a few 4Mbit EPROM I found and EPROM programmer costs more than a few wires and a socket connected to my Mega so I thought I'd wire up my Mega with the EPROM and dump data to serial monitor.
No line space, no carriage return, nothing just straight 0-9 and A-Fs, just to save directly to text file to look it up and change to bin file if I need to keep it for later programming. How would I write data to the monitor that way? It's coming out with lots of spaces which makes it hard for me to read or save to text file.
No error on my IDE, just want to see how I could fix serial print formatting.
// Digital I/O pin assignments
const int romOE = 21;  // ROM /output enable
const int romA0 = 30;  // ROM address lines
const int romA1 = 31;
const int romA2 = 32;
const int romA3 = 33;
const int romA4 = 34;
const int romA5 = 35;
const int romA6 = 36;
const int romA7 = 37;
const int romA8 = 38;
const int romA9 = 39;
const int romA10 = 40;
const int romA11 = 41;
const int romA12 = 42;
const int romA13 = 43;
const int romA14 = 44;
const int romA15 = 45;
const int romA16 = 46;
const int romA17 = 47; // 256k
const int romA18 = 48; // 512k ROM
const int romD0 = 22;  // ROM data lines
const int romD1 = 23;
const int romD2 = 24;
const int romD3 = 25;
const int romD4 = 26;
const int romD5 = 27;
const int romD6 = 28;
const int romD7 = 29;
// Global variables
unsigned long romAddr = 0L; // up to 32-bit current address
byte romData = 0;           // Eight-bit ROM data
  Serial.begin(115200);           // Enable serial output
                                  // Set I/O initial parameters
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW); // Turn off activity indicator
  pinMode(19, OUTPUT);            // activity LED
  pinMode(20, OUTPUT);            // finished LED
  digitalWrite(20, LOW);
  pinMode(romOE, OUTPUT);
  digitalWrite(romOE, HIGH);      // Negate ROM output enable
  for (int i = 0; i < 18; ++i)     //address
    pinMode(romA0 + i, OUTPUT);   // Set direction of ROM address lines
  for (int i = 0; i < 8; ++i)
    pinMode(romD0 + i, INPUT);            // Set direction of ROM data lines
  ResetAddr();                            // Set current ROM address to 0x0000
  delay(8000);                            // Delay for time to open serial window in IDE to capture output
  digitalWrite(LED_BUILTIN, HIGH);        // Turn on activity indicator
                                          // Read ROM and send data to serial port
  for (unsigned long records = 0; records < 524288; ++records)
  {                                       // straight 512k for A0-A18,
     digitalWrite(19, !digitalRead(19));  // blinky LED to show activity on D19
      romData = ReadData();               // Get eight-bit data from ROM at current address
      Serial.print(romData);              // Print ROM data byte to serial port
      IncrAddr();                         // Increment ROM address lines
    Serial.print("");                     // Print end-of-line to serial port
  digitalWrite(20, 0);                    // finished, turn on LED on D20
  while (1);                              // Loop continuously until reset
void ResetAddr()                          // Reset ROM address bus to 0x0000
{                                         // runs only once at setup
  romAddr = 0;                            // Reset address variable
  for (int i = 0; i < 18; ++i)            // address
  {                                       // 19 address lines A0-A18 for 512k x 8 ROM
    digitalWrite(romA0 + i, LOW);         // Set all ROM address lines low
void IncrAddr()                           // Increment to next address
  for (int i = 0; i < 18; ++i)            // Start with A0, check each bit through whatever
    if (bitRead(romAddr, i) == 0)         // Check current bit; if zero, increment current ROM address bit
    {                                     //   and equivalent ROM address bit output, then return,
      bitSet(romAddr, i);                 //   since no carry is needed.
      digitalWrite((romA0 + i), HIGH);
      return;
    bitClear(romAddr, i);                 // Otherwise, clear current address bit and equivalent ROM
    digitalWrite((romA0 + i), LOW);       //   address bit output, then loop to increment
  }                                       //   next higher address bit.
byte ReadData()                           // Read 8-bit ROM data at current address
  byte result;                            // Eight-bit result
  digitalWrite(romOE, LOW);               // Assert ROM output enable
  delayMicroseconds(10);                  // Delay to let data lines settle
  result = 0;                             // Initialize result
  {                                       // Check D0 through D7 and insert high bits into result
    if (digitalRead(romD0 + i) == HIGH)
      bitSet(result, i);
  return result;                          // Return result to caller
try changing
to
Serial.print(romData, HEX);
That's not going to work for a couple of reasons.
  • you aren't printing in HEX.
  • Serial.print does not include leading zero if appropriate
// This will print a byte as a pair of HEX digits with leading zero
  static char hex_digits[3];
  sprintf(hex_digits,"%02X",ramData);
  Serial.print(hex_digits);
If you send one long line to the Serial monitor, you won't be able to read it. It be somewhat more readable if you send a linefeed after every 32 bytes.
I also doubt that its buffer will allow it to store a megabyte of data anyway so you won't be able to copy and paste the entire output into a file.
Pete
el_supremo:
That helps!
Pete
I was planning to save it into text file and using something like Wordpad, most text programs have word wrapping. I'm just using serial monitor to catch the incoming data
If the serial monitor will save one line that is a megabyte long, the rest is just cut and paste.
Pete
el_supremo:
Pete
I decided to add line return after every 32 bytes, should be easier to copy and paste. I can remove line return when converting to binary format.
