How to free memory?
i have this code:
typedef struct XbeeData {
int lenght;
uint8_t *data;
struct XbeeData XData;
void ReciveXbee (struct XbeeData *XData){
XData->lenght = getlenght();
XData->data = (uint8_t *)malloc(getlenght()*8);
for (int i=0; i<getlenght(); i++)
XData->data* = getdata(i);*
  • ReciveXbee(&XData); *
    [/quote]
    And i try much options but didn’t works any.
    thanks!!
I suppose that the reason you used a pointer in XbeeData is that the length of the data returned is unknown. You'd need to free the space you allocated within the loop() function (e.g. free(XData->data) after each ReciveXbee call.
But I guess I'd check to make sure that every malloc is matched with a free throughout the program.
Thanks AlphaBeta i found a solution:
int lenght;
uint8_t *data;
XData->data = getdata(i);
    ** free(XData.data);**
  • ReciveXbee(&XData);*
    [/quote]
It seems to me what you're doing there isn't right. You are now free-ing memory that hasn't be allocated yet. Which is illegal.
You should use free after you have used the data from the struct and no longer need it.
