I need wifi shild every 10 minutes, so i want to disconnect the wifi shild to save power. In program i use client.stop(); and WiFi.disconnect();, but the wifi link led is still on.
Thanks for helping
Thanks for helping
Which WiFi shield? Typically shields draw power all the time. If that is not what you want, you'll need a non-shield version or to connect the shield to a breadboard and re-wire the connections to the Arduino. The power to the shield as a shield can not be controlled by software. The power to the shield, on the breadboard, could be.
I have this wifi shield http://arduino.cc/en/Main/ArduinoWiFiShield . From which pin wifi shileld gets electricity. Is it pin 5V?
Hello,
I've the same issue and it's seems to be a well-known issue.
It seems there is an automatic process to reconnect the shield, so I tried to force the disconnection with this code:
actualTime=millis();
startTime= millis();
while(actualTime - startTime < 45000 ) {
WiFi.disconnect();
actualTime = millis();
With this code, the shield is disconnected but it is impossible to reconnect the shield after this disconnection
=> Afterward, the shield won't be recognized by the Arduino or the status returned by the function "begin" is = 4, and not WL_CONNECTED.
(Arduino Duemilanove for me)
Does anyone have any idea of how to solve this?
Thanks,
Romain.
