How to generate AC Square wave
Hi guys,
I'm trying to do an electrolysis experiment where i have two probes (ofcourse)
Basically I feed the probes 10Volts DC however.. i have to switch polarity every 5 seconds.
Doing it by hand is ridiculous right? Should I not be able to get an arduino to do it?
Any advice guys.. I have an arduino but am a TOTAL NOOB at this stuff..
I can barely work the soldering gun LOL
HELP!!!!
A DPDT relay?
DPDT relay or H-bridge (which does the same thing, only solid state - meant to reverse motors) is just what you need. Make sure it can handle the expected current.
Run the DC thru a DPDT relay. In NC position, 10V/GND is applied, switch to NO position and GND/10V is applied.
Transistor to sink current thru the coil to energize it.
a QUICK google and yeah THATS seems what i need.
Same as reversing a motor ... you know of any projects that incorporate
DPDT relay for reversing polarity every x seconds?
DPDT on arduino timer circuit for idiots?
wishful thinking i know.
Thanks for the quick reply my friend at least I'm in the ballpark now.
Cheers
Look at blink without delay.
Replace LED with transistor driving relay.
Job done.
Wow thanks guys! yeah blink circuit and swap out led for transister..
Ok i think I got a handle on the direction..
I guess the only question that remains is what transister to use.
I will be pumping 10 to 12 volts MAX and 4 TO 8 AMPS.
Thanks for all the help!!
Cheers
The transistor will be driving the relay - the load current isn't an issue for the transistor, only the relay.
AWOL:
Gotcha duh! "I knew that!" lol
