How to generate around 3V TTL clock with 9.6 kHz, 50% duty cycle?
Hi All,
I am new in Arduino. I would like to generate around 3V TTL clock with 9.6 kHz, 50% duty cycle. Does anyone know how to do it? Or just give me some ideas to generate this signal. Thanks so much!
Tim
~3V TTL Analog signal
A what?
AWOL:
A what?
Thanks for the reply, just edited.
Tim
generate a 5Volt one and use a voltage divider to make it 3V
then run a loop like this?
d = 1000000 / 9600 / 2; // or something like this, they might even differ slightly
while(1)
  digitalWrite(pin, HIGH);
  delayMicroseconds(d);
  digitalWrite(pin, LOW);
another way is to use a timer interrupt an switch the status of the pin in the ISR
robtillaart: generate a 5Volt one and use a voltage divider to make it 3V
while(1)
Thanks Rob, I just tried the first method as you mentioned. I connected the signal in Oscilloscope, but the ~9kHz signal is shaking by a small range in x-axis. I also tried lower frequency, the signal looks very stable.
For the second method, do you have recommended reference?
Tim
ztw317: I am new in Arduino. I would like to generate around 3V TTL clock with 9.6 kHz, 50% duty cycle. Does anyone know how to do it? Or just give me some ideas to generate this signal. Thanks so much!
The easiest way to generate 50% duty cycle signals in the audible frequency range is the Arduino tone function: http://www.arduino.cc/en/pmwiki.php?n=Reference/Tone
