Hello!
I had been working on half bridge bidirectional DC DC converter for quit long. Here I want to operate the converter in both synchronous buck and boost mode separately.
•For that I want to generate complementary pwm pulses for p and n channel MOSFETs.
•I also want to vary the pwm pluses externally with potentiometer.
I have tried working with analogRead() and analogWrite() for creating the desired pulses for my converter, but it didn't worked in synch. boost mode. I didn't found it much accurate.
So, now I want to use the internal Timer/Counter for generating the complementary pwm pulses with a dead time of 125ns at pin 3 and 11 of Arduino Uno.
I had also gone through the Atmega328P datasheet...but frankly speaking I ended up with my head spinning off. So pls, if anybody can help me out. I will be glad to seek your help.
Thank you in advance.
