Hello, I'm thinking of using a temperature controlled wearable actuator for a new project. It should be stapped onto the skin and heat up depending on certain states. I believe I should make use of some heat generating device and, as I don't want to burn someone, some temperature sensor to realize this.
Unfortunately I don't have an ideo how to generate the heat. Is there any way to heat up some small sheet of metal? How would I do that? What would be the least energy consuming way?
Here is a link to flexible heaters. I suppose wearing solid blocks will be incomfortable. These heaters need to be powered say by a transistor so that arduino doesn't have to provide the power, just a voltage.
Hope this helps. http://www.minco.com/products/heaters.aspx?id=73
