Hi there,
I want to control a RC plane by generating PPM signal from Arduino, I'm a n00b in this field.
I want simple technique in coding (as I'm not expert in making sketches and libraries)
I searched a little on Google and found this Library
A PPM stream for R/C is just a sequence of variable-width (PWM) pulses (one per channel),, each with a tiny LOW gap between them and a much wider gap marking the frame end. The pulses are typically 1 to 2 ms wide, and the whole frame is 20ms long
PaulS:
Servos are not driven by PWM. I have no idea why so many people think that they are.
I don't think they are - I know they are driven by PWM.
The position of the servo shaft is governed by width of the control pulse. Pulse Width Modulation
PPM is used between the RC tx and rx. Servo PWM is used between the RC rx and the servo. Internal to the servo typical motor control PWM is used to drive the servo motor H-bridge.
