how to get +12 to -12V signals to arduino analog input
I have to get 12v to -12 range for read the signal of my position sensor or at least 5v to -5v how it is possible?? :frowning:
Think of it roughly like this.
Add 12v to the signal to change the range to 0 to 24v
Use a voltage divider to reduce that to a range of 0 to 5v.
Alternatively use a diode to lose the negative part and a voltage divider to reduce the positive part to the range 0 to 5v
And you will probably bet a lot better advice if you tell us what the project is.
...R
-12/+12 is the original specified range of RS232 so you could get a MAX232 or similar chip which converts that to TTL (0 to 5V).
Oh. Justa sec. Is that -12 to +12 analog? If so, forget what I just said.
Pete
This move the voltage shows how.
Mark
