How to get 5V from phone charger
Members
I have used an old usb cable to supply a board with 5V. When I plug this into my PC usb I get 5V. When I plug this into my phone charger I receive only 2.2V.
I snipped the end of an old charger cable and used the following wires: Red-Supply & Green-ground & Brown- not connected & White- not connected.
Any ideas on why this is happening?
Thanks
Some phone chargers will only put out a lower voltage until they see a load on the output.
BJHenry:
And some phone chargers output unfiltered DC pulses. What did you use to measure the voltage?
Paul
fnb111:
Members
Thanks
Supply wires should be red and black. white and green are data wires. Your "brown" is likely the negative
supply.
Hi All,
I think Paul is correct. I have seen this with
another type of battery charger. The battery
acts like a filter capacitor to the half-wave
rectified current being supplied by the charger.
A half-wave rectified voltage has an average
value of 0.45 times the peak voltage* supplied.
The battery does not care what the waveform
is like as long as the peak is higher than its
present terminal voltage. (*for sine waves)
Herb
