How to get a temperature reading from a single DS18b20
I want to get a temperature reading from ds18b20 with a microcontroller and even though there is so many resources on the internet I could not manage to do it. None of the codes work on their own and I am just unable to figure out how to convert them to my microcontrollers timings etc. Almost all the codes are written in C and this makes it even more difficult for me to understand what happens timing wise and port wise (as opposed to assembly language) I would really appreciate if someone told me what values to assign the port and how many us's to wait in between etc.
I know reset, write1,write0,read codes are necessary. these are the ones I have written (even if you know how to use it on a different device, I can convert them. I just need the timings and the port values)
Reset--
pin=0
wait 500us
pin=1
wait 500us
write1--
pin=0
wait 1us
pin=1
wait 60us
write0--
pin=0
wait 60us
pin=1
read--
pin=0 us
wait 1us
pin=1 us
wait 13 us (has to be 15us according to the datasheet but previous instructions already should take time)
c (carry) = pin (value read)
wait 60us
how would I get the temperature measured?
reset
send CCh (write1 write0 write1 write0 write1 write0 write1 write0)
send 44h
wait 1 sec (for the conversion, I assume it is 12 bits by default)
reset
send CCh
send BEh
read (do this 16 times and I'll have the measurements MSB.(0:7) and then LSB(0:7))
am I thinking wrong? what do I need to fix? Is there a clean assembly code for ds18b20 (so that I can understand what actually goes on without much abstractions)? I could use a c code but none of them are for the microcontroller I have and I need to adjust the delays and I couldn't get any of them to work. Any help would be much appreciated
After tens of hours wasted not understand what I'm doing wrong, I miraculously managed to read 85C from the machine (using a c code which I do not understand how it works, moreover I overwrote it so now it doesnt work. I guess I make it work again though) (which is the default value the temperature registry starts with) So I am assuming I did not actually ConvertTemperature (44h)?
The DS18b20 datasheet explains the protocol in great detail, and it is your best resource. What type of microcontroller?
jremington: The DS18b20 datasheet explains the protocol in great detail, and it is your best resource. What type of microcontroller?
I tried my codes on DS89C450 I think. 1MachineCycle = 1ClockCycle and Clock = 11.0592Mhz. So 1MachineCycle instructions take 90ns to execute. But I will need to adapt the code to currently unknown type of microcontroller (it will be 8051 based, i can translate the delays if I know how long they should actually be) With the assembly code I have written I ended up reading a constant "0000 0001 0001 0100" Which corresponds to 17.25C but it cannot be a proper value (because it was hotter) and because it couldn't be constant.
I have studied the datasheet but I cannot make it work.
