Hi guys, am a little new at this so i sincirely need your help.
So I have a temperature & humidity sensor i got from http://www.aosong.com/en/products-70.html which is probably based on the AM2315C - Encased I2C Temperature/Humidity Sensor https://learn.adafruit.com/am2315-encased-i2c-temperature-humidity-sensor?view=all
I am trying to get it to read the temperature and humidity values, via an STM32F103C8T6 that am using as my microcontroller.
So whats going on is when i try this code:
#include <Adafruit_AHTX0.h>
Adafruit_AHTX0 aht;
sensors_event_t humidity, temp;
if (! aht.begin()) {
Serial.println("Could not find AHT? Check wiring");
while (1) delay(10);
Serial.println("Temperature C || Humidity %rH");
aht.getEvent(&humidity, &temp);// วัดค่าอุณหภูมิและความชื้น
Serial.print(temp.temperature);
Serial.print(" ");
Serial.println(humidity.relative_humidity);
I got from this guy on YouTube and uploaded it in my Arduino Uno; it works perfectly, tried it with my ESP 32, works flawlessly and reads accurate values, BUT when i try to use the same code with my STM32 (STM32F103C8T6) Blue Pill it says "Could not find AHT? Check wiring" probably because of this line of course
I'm not sure if it's something to do with the I2C pins and how they are defined for each board, or maybe the STM32F103C8T6 requres a different library, am not sure. By the way i also tried adding 2 10k pull-up resistors between the SDA & SCL ( AM2315C) and the SDA & SCL (STM32F103C8T6), still no change.
My pinout is as follows:
STM32F103C8T6 >> AM2315C
5v (I tried with 3.3v too) >> VDD
GND GND
PB6 (SCL) >> I2C SCL (White Line)
PB7 (SDA) >> I2C SDA (Yellow Line)
I need this to work for a project am doing and i would apppreciate if someone pointed me in the right direction, please let me know if i need to share more info so aid in the solving process.
