Hi, I am doing a project to measure the weight of an object by using ESP32 and load cell. The library that I am using is the HX711_ADC by Olav Kallhovd (can be installed by searching in Manage Library). The readings that I obtained is not that accurate so I want to get the average of 5 readings. The code to get one reading is shown below:
#include <HX711_ADC.h>
#if defined(ESP8266)|| defined(ESP32) || defined(AVR)
#include <EEPROM.h>
#endif
//pins:
const int HX711_dout = 19; //mcu > HX711 dout pin
const int HX711_sck = 21; //mcu > HX711 sck pin
//HX711 constructor:
HX711_ADC LoadCell(HX711_dout, HX711_sck);
float i;
float weight_limit = 10.0;
const int calVal_calVal_eepromAdress = 0;
unsigned long t = 0;
delay(10);
Serial.println("Starting...");
float calibrationValue; // calibration value
calibrationValue = 696.0; // uncomment this if you want to set this value in the sketch
#if defined(ESP8266) || defined(ESP32)
//EEPROM.begin(512); // uncomment this if you use ESP8266 and want to fetch this value from eeprom
#endif
//EEPROM.get(calVal_eepromAdress, calibrationValue); // uncomment this if you want to fetch this value from eeprom
LoadCell.begin();
unsigned long stabilizingtime = 2000; // tare preciscion can be improved by adding a few seconds of stabilizing time
boolean _tare = true; //set this to false if you don't want tare to be performed in the next step
LoadCell.start(stabilizingtime, _tare);
if (LoadCell.getTareTimeoutFlag()) {
Serial.println("Timeout, check MCU>HX711 wiring and pin designations");
else {
LoadCell.setCalFactor(calibrationValue); // set calibration factor (float)
Serial.println("Startup is complete");
while (!LoadCell.update());
Serial.print("Calibration value: ");
Serial.println(LoadCell.getCalFactor());
Serial.print("HX711 measured conversion time ms: ");
Serial.println(LoadCell.getConversionTime());
Serial.print("HX711 measured sampling rate HZ: ");
Serial.println(LoadCell.getSPS());
Serial.print("HX711 measured settlingtime ms: ");
Serial.println(LoadCell.getSettlingTime());
Serial.println("Note that the settling time may increase significantly if you use delay() in your sketch!");
if (LoadCell.getSPS() < 7) {
Serial.println("!!Sampling rate is lower than specification, check MCU>HX711 wiring and pin designations");
else if (LoadCell.getSPS() > 100) {
Serial.println("!!Sampling rate is higher than specification, check MCU>HX711 wiring and pin designations");
static boolean newDataReady = 0;
const int serialPrintInterval = 500; //increase value to slow down serial print activity
// check for new data/start next conversion:
if (LoadCell.update()) newDataReady = true;
// get smoothed value from the dataset:
if (newDataReady) {
if (millis() > t + serialPrintInterval) {
i = LoadCell.getData();
Serial.print("Load_cell output val: ");
Serial.println(i);
newDataReady = 0;
t = millis();
// receive command from serial terminal, send 't' to initiate tare operation:
if (Serial.available() > 0) {
char inByte = Serial.read();
if (inByte == 't') LoadCell.tareNoDelay();
// check if last tare operation is complete:
if (LoadCell.getTareStatus() == true) {
Serial.println("Tare complete");
I tried to use a for loop to get the average reading but the serial monitor will get spammed by showing 5 readings per iteration.
#include <EEPROM.h>
#endif
//pins:
float i;
delay(10);
#endif
LoadCell.begin();
else {
if (newDataReady) {
for (int a=0; a<5; a++)
newDataReady = 0;
t = millis();
accumulated = accumulated + i;
averageweight = accumulated/5;
Serial.println(averageweight);
Can someone help out with the coding as I am not familiar with this library? Thank you
