How to get BLAS/LAPACK (or any other matrix math library) on Arduino?
Hey all,
I’m attempting a project that will require quite a bit of matrix math with floating point numbers. I will be using the BLE SENSE for this project.
I will need dot products, vector norms, matrix multiplication, matrix transpose, matrix inversion, Cholesky decomposition etc.
I’m not the best C++ programmer. So while I can derive these algorithms myself on paper, it will take me time to implement them properly on the Arduino; and they probably wouldn’t be optimal resource wise.
I don’t know where to start. I have read that BLAS/LAPACK is a decent library for C++, but most of the guides I’ve read aren’t for Arduino and somehow imply that the library must be compiled ahead of time.
I don’t understand why I cannot just put the library files (.cpp, .h) in flash and compile it alongside my project?
Can someone please point me in the right direction?
First of all you need an Arduino with enough RAM, best with hardware floating point support. Choose one and find out what systems and libraries are supported on that target.
Or use a RasPi or PC for number crunching.
DrDiettrich:
I'll be using the Nano BLE Sense. I can strip down the libraries to just the functions I need, but first I need to find a library that works.
I cannot seem to find a lightweight library. How is everyone else doing matrix math/control in their projects?
BLAS and LAPACK are often implemented in Fortran, the Arduino IDE doesn't ship with Fortran compilers.
There are pure C and C++ implementations as well, but they often use advanced features to detect cache properties, use thread pools, memory pools, logging etc. that are not supported on most microcontrollers.
For simple operations on small matrices, I use my own implementation. I'll see if I can clean it up a bit and upload them to GitHub.
Do you need variable-size matrices or are the dimensions fixed at compile-time? How large? Do you need eigenvalue solvers? SVD? Riccati?
What algorithms do you want to run?
Pieter
PieterP:
Pieter
I'm new to embedded projects/programming in general, and I'm surprised that there isn't a common library for this sort of thing.
I need matrix transpose, matrix inverse, anything that can solve Ax = b (Gauss-Seidel, or Gauss-Jordan), eigen-decomposition (i.e. the square matrix case of SVD).
I think that would be enough to get me started, I really appreciate the help! I need a quadratic programming solver capable of handling inequality constraints, but I think I might attempt that one on my own if I can get the other pieces; but if you've got that handy too, I wouldn't complain :slight_smile:
I have a lot of experience in MATLAB, but not that much in C/C++; it actually caught me by surprise that there was no default Matrix data-type.
For basic matrix operations, I use a stripped down version of this macro library. It uses no loops, so executes more quickly at the expense of some program memory.
For small Arduinos, the most straightforward approach to solve complex linear algebra problems is to remove from large code libraries the specific routines you need to solve the problem at hand, and include them in the code.
For an example of how to use the above macro library, below is part of a code that solves the specific problem of determining the rotation/translation matrices relating four points in an image to the camera position in space (called “the PnP problem”). It runs fine on a Uno, with plenty of program memory left over.
// Based on lambda_twist code published by Persson and Nordberg:
// https://github.com/midjji/lambdatwist-p3p
// theory paper at
// http://openaccess.thecvf.com/content_ECCV_2018/html/Mikael_Persson_Lambda_Twist_An_ECCV_2018_paper.html
// S. J. Remington 8/2019
//p3p solves rotation and translation from first 3 points,
// uses the fourth point to decide which solution is best.
//input: 4 sets of real world coordinates x1..x4,
//       4 sets of distortion corrected camera coordinates y1..4
//output: camera Rs, Ts final solution
//returns 0 if no solution or number of the valid solution (1-4)
int p3p(float x1[3], float x2[3], float x3[3], float x4[3],
        float y1[3], float y2[3], float y3[3], float y4[3])
  float b12, b13, b23;
  VEC_DOT_PRODUCT(b12, y1, y2);
  VEC_DOT_PRODUCT(b13, y1, y3);
  VEC_DOT_PRODUCT(b23, y2, y3);
  b12 = -2.0 * b12;
  b13 = -2.0 * b13;
  b23 = -2.0 * b23;
  float d12[3], d13[3], d23[3];
  VEC_DIFF(d12, x1, x2);
  VEC_DIFF(d13, x1, x3);
  VEC_DIFF(d23, x2, x3);
  float d12xd13[3], a12, a13, a23;
  VEC_CROSS_PRODUCT(d12xd13, d12, d13);
  VEC_DOT_PRODUCT(a12, d12, d12); //squared length
  VEC_DOT_PRODUCT(a13, d13, d13);
  VEC_DOT_PRODUCT(a23, d23, d23);
  // a*g^3 + b*g^2 + c*g + d = 0
  float c31, c23, c12, blob, s31_squared, s23_squared, s12_squared;
  c31 = -0.5 * b13;
  c23 = -0.5 * b23;
  c12 = -0.5 * b12;
  blob = (c12 * c23 * c31 - 1.0);
  s31_squared = 1.0 - c31 * c31;
  s23_squared = 1.0 - c23 * c23;
  s12_squared = 1.0 - c12 * c12;
  float p0, p1, p2, p3;
  p3 = (a13 * (a23 * s31_squared - a13 * s23_squared));
  p2 = 2.0 * blob * a23 * a13 + a13 * (2.0 * a12 + a13) * s23_squared
       + a23 * (a23 - a12) * s31_squared;
  p1 = a23 * (a13 - a23) * s12_squared - a12 * a12 * s23_squared
       - 2.0 * a12 * (blob * a23 +  a13 * s23_squared);
  p0 = a12 * (a12 * s23_squared - a23 * s12_squared);
  //printf("p3..0 %10.5e %10.5e %10.5e %10.5e\n",p3,p2,p1,p0);
  // solve cubic
  float g;
  if (fabs(p3) >= fabs(p0)) {
    if (p3 == 0.0) return 0;
    p3 = 1.0 / p3;
    p2 = p2 * p3;
    p1 = p1 * p3;
    p0 = p0 * p3;
    g = cubick(p2, p1, p0);
  else {
    if (p0 == 0.0) return 0;
    // lower numerical performance
    g = 1.0 / (cubick(p1 / p0, p2 / p0, p3 / p0));
  } //end if (fabs(p3)
  //printf(" gamma %10.5e\n",g);
  //  Serial.print("gamma ");
  //  Serial.println(g,5);
  float A00, A01, A02, A11, A12, A22;
  A00 = a23 * (1.0 - g);
  A01 = (a23 * b12) * 0.5;
  A02 = (a23 * b13 * g) * (-0.5);
  A11 =  a23 - a12 + a13 * g;
  A12 =  b23 * (a13 * g - a12) * 0.5;
  A22 =  g * (a13 - a23) - a12;
  float A[3][3] = {{A00, A01, A02}, {A01, A11, A12}, {A02, A12, A22}};
  float V[3][3], L[3];
  // get the eigenvalues
  eig0(A, V, L);
  //print_v3("E ",L);
  //print_m33("EM",V);
  float v, Ls[4][3];
  int valid = 0; //number of valid solutions found
  //the two eigenvalues should have opposite signs
  v = sqrt(fmax(0.0, -L[1] / L[0]));
  // use the t=Vl with t2,st2,t3 and solve for t3 in t2
  //+v block locals redefined and reused
    float s, w0, w1, w2, a, b, c, d, tau, tau1, tau2;
    s = v;
    w2 = 1.0 / ( s * V[0][1] - V[0][0]);
    w0 = (V[1][0] - s * V[1][1]) * w2;
    w1 = (V[2][0] - s * V[2][1]) * w2;
    a = 1.0 / ((a13 - a12) * w1 * w1 - a12 * b13 * w1 - a12);
    b = (a13 * b12 * w1 - a12 * b13 * w0 - 2.0 * w0 * w1 * (a12 - a13)) * a;
    c = ((a13 - a12) * w0 * w0 + a13 * b12 * w0 + a13) * a;
    if (b * b - 4.0 * c >= 0 ) {
      root2real(b, c, &tau1, &tau2);
      if (tau1 > 0) {
        float l1, l2, l3;
        tau = tau1;
        d = a23 / (tau * (b23 + tau) + 1.0);
        l2 = sqrt(d);
        l3 = tau * l2;
        l1 = w0 * l2 + w1 * l3;
        if (l1 >= 0) {
          Ls[valid][0] = l1;
          Ls[valid][1] = l2;
          Ls[valid][2] = l3;
          valid = valid + 1;
      if (tau2 > 0) {
        float l1, l2, l3;
        tau = tau2;
        l2 = sqrt(d);
        l3 = tau * l2;
        if (l1 >= 0) {
          Ls[valid][0] = l1;
          Ls[valid][1] = l2;
          Ls[valid][2] = l3;
          valid = valid + 1;
  }  //end +v block
  //-v block locals redefined and reused
    s = -v;
      if (tau1 > 0) {
        float l1, l2, l3;
        tau = tau1;
        l2 = sqrt(d);
        l3 = tau * l2;
        if (l1 >= 0) {
          Ls[valid][0] = l1;
          Ls[valid][1] = l2;
          Ls[valid][2] = l3;
          valid = valid + 1;
      if (tau2 > 0) {
        float l1, l2, l3;
        tau = tau2;
        l2 = sqrt(d);
        l3 = tau * l2;
        if (l1 >= 0) {
          Ls[valid][0] = l1;
          Ls[valid][1] = l2;
          Ls[valid][2] = l3;
          valid = valid + 1;
  } //end -v block
  printf("valid solutions %d\n",valid);
//  Serial.print(F(" valid solutions"));
//  Serial.println(valid);
  float Xinv[3][3];
  { //block
    float X[3][3] = { //local
      {d12[0], d13[0], d12xd13[0]},
      {d12[1], d13[1], d12xd13[1]},
      {d12[2], d13[2], d12xd13[2]}
    float detx = 0.0;
    INVERT_3X3(Xinv, detx, X);
  } //end block
  int i, i_min;
  float min_rms = 1.0e6; //for sorting solutions
  i_min = 1000;
  float R[3][3], T[3];  //locals
  for (i = 0; i < valid; i++) {
    float ry1[3], ry2[3], ry3[3]; //result vectors
    float yd1[3], yd2[3], yd1xd2[3]; //deltas
    float LR[3] = {Ls[i][0], Ls[i][1], Ls[i][2]};
    // Gauss-Newton refinement step (checked by perturbation: OK!)
    refine_lambda(LR, a12, a13, a23, b12, b13, b23);
    //compute the rotation
    VEC_SCALE(ry1, LR[0], y1);
    VEC_SCALE(ry2, LR[1], y2);
    VEC_SCALE(ry3, LR[2], y3);
    VEC_DIFF(yd1, ry1, ry2);
    VEC_DIFF(yd2, ry1, ry3);
    VEC_CROSS_PRODUCT(yd1xd2, yd1, yd2);
    float Y[3][3] = {
      {yd1[0], yd2[0], yd1xd2[0]},
      {yd1[1], yd2[1], yd1xd2[1]},
      {yd1[2], yd2[2], yd1xd2[2]}
    MATRIX_PRODUCT_3X3(R, Y, Xinv);  //local R
    //solve translation using first point (arbitrary choice)
    // now try solving with all 3 points and average.
    // (averaging 3 points not seem to help using calculated camera coords
    //  so repeat test with real cam coords)
    { //block
      float ry[3], rsum[3] = {0.0};
      MAT_DOT_VEC_3X3(ry, R, x1);
      //    Ts=(ry1 - (Rs*x1')');
      VEC_DIFF(rsum, ry1, ry);
      // next point
      MAT_DOT_VEC_3X3(ry, R, x2);
      VEC_DIFF(ry, ry2, ry);
      VEC_SUM(rsum, rsum, ry);
      // and third
      MAT_DOT_VEC_3X3(ry, R, x3);
      VEC_DIFF(ry, ry3, ry);
      VEC_SCALE(T, 1.0 / 3.0, rsum);  //result = local T
    float rms = test_sol(R, T, x1, x2, x3, x4, y1, y2, y3, y4);
    if (rms < min_rms) {
      COPY_MATRIX_3X3(Rs, R); //save this matrix solution
      VEC_COPY(Ts, T); //and this vector
      i_min = i; //solution index
      min_rms = rms;
    printf("index %d rms = %8.5f\n",i_min, min_rms);
//      Serial.print("#");
//      Serial.print(i_min);
//      Serial.print(F(" rmsE = "));
//      Serial.println(min_rms);
  }  //end for i<valid
  if (valid > 0) return i_min + 1; //solution number (index+1)
  else return 0;  //nada
} //end p3p
Did someone realize that the 8 Bit AVR controllers lack even a DIV instruction and have to do all divisions sequentially in code? And that all registers are 8 Bit, so that many instructions are required to execute a multi-byte floating point operation :frowning:
Yes, many people have realized that, beginning with 8-bit personal computers running at 1 MHz, around 40 years ago.
@sunmisola is using a Nano 33 BLE Sense, which has a pretty capable 32 bit nRF52840 microcontroller. This board is able to be used for machine learning applications with TensorFlow Lite.
jremington:
For an example of how to use the above macro library, below is part of a code that solves the specific problem of determining the rotation/translation matrices relating four points in an image to the camera position in space (called "the PnP problem"). It runs fine on a Uno, with plenty of program memory left over.
Thanks! I like how straightforward this is macro approach is. I think I can start from here and build on it. Seems I just need to make the core/low-level matrix functions macros and include them in this header then I can build the larger more complicated functions I need.
Only downside to this approach seems if I decide that a matrix needs to be larger (defined by certain control parameters that I will be tuning), I would have to add that configuration manually to the header file.
Is there a way to generalize this for different sizes?
Undoubtedly, but I suspect it would take less time to type the macros in by hand than to write and debug the code that would generate the macro.
With 1 Mb of code space on that processor, you can afford to include general purpose matrix routines. I’ve attached one that I use for C programs (Windows/Code::Blocks), obtained from Matrices and Linear Algebra
I’ve used it a lot, and never had a problem with it.
www_mymathlib_com.c (112 KB)
I've pushed my matrix code to GitHub, you can find it at GitHub - tttapa/Linear-Algebra at arduino
Personally, I find it much easier to use than the C libraries mentioned earlier, because the syntax is more readable thanks to operator overloading.
For example:
  [color=#434f54]// Systems of equations[/color]
  [b][color=#d35400]SquareMatrix[/color][/b] [color=#000000]A[/color] [color=#434f54]=[/color] [color=#000000]{[/color]
    [color=#000000]{[/color][color=#000000]1[/color][color=#434f54],[/color] [color=#000000]6[/color][color=#434f54],[/color] [color=#000000]2[/color][color=#000000]}[/color][color=#434f54],[/color]
    [color=#000000]{[/color][color=#000000]3[/color][color=#434f54],[/color] [color=#000000]2[/color][color=#434f54],[/color] [color=#000000]1[/color][color=#000000]}[/color][color=#434f54],[/color]
    [color=#000000]{[/color][color=#000000]5[/color][color=#434f54],[/color] [color=#000000]1[/color][color=#434f54],[/color] [color=#000000]3[/color][color=#000000]}[/color][color=#434f54],[/color]
  [color=#000000]}[/color][color=#000000];[/color]
  [b][color=#d35400]Vector[/color][/b] [color=#000000]x[/color] [color=#434f54]=[/color] [b][color=#d35400]Vector[/color][/b][color=#434f54]:[/color][color=#434f54]:[/color][color=#d35400]ones[/color][color=#000000]([/color][color=#000000]3[/color][color=#000000])[/color][color=#000000];[/color]
  [b][color=#d35400]Vector[/color][/b] [color=#000000]v[/color] [color=#434f54]=[/color] [color=#000000]A[/color] [color=#434f54]*[/color] [color=#000000]x[/color][color=#000000];[/color]
  [b][color=#d35400]HouseholderQR[/color][/b] [color=#000000]qr[/color][color=#000000]([/color][color=#000000]A[/color][color=#000000])[/color][color=#000000];[/color] [color=#434f54]// QR factorization[/color]
  [b][color=#d35400]Vector[/color][/b] [color=#000000]x_solution[/color] [color=#434f54]=[/color] [color=#000000]qr[/color][color=#434f54].[/color][color=#d35400]solve[/color][color=#000000]([/color][color=#000000]v[/color][color=#000000])[/color][color=#000000];[/color]
  [color=#434f54]// Vector operations[/color]
  [b][color=#d35400]RowVector[/color][/b] [color=#000000]a[/color] [color=#434f54]=[/color] [color=#000000]{[/color][color=#000000]1[/color][color=#434f54],[/color] [color=#000000]2[/color][color=#434f54],[/color] [color=#000000]3[/color][color=#000000]}[/color][color=#000000];[/color]
  [b][color=#d35400]RowVector[/color][/b] [color=#000000]b[/color] [color=#434f54]=[/color] [color=#000000]{[/color][color=#000000]4[/color][color=#434f54],[/color] [color=#000000]6[/color][color=#434f54],[/color] [color=#000000]5[/color][color=#000000]}[/color][color=#000000];[/color]
  [b][color=#d35400]RowVector[/color][/b] [color=#000000]c[/color] [color=#434f54]=[/color] [color=#000000]a[/color][color=#434f54].[/color][color=#d35400]cross[/color][color=#000000]([/color][color=#000000]b[/color][color=#000000])[/color][color=#000000];[/color]
  [color=#00979c]double[/color] [color=#000000]d[/color]    [color=#434f54]=[/color] [color=#000000]a[/color][color=#434f54].[/color][color=#d35400]dot[/color][color=#000000]([/color][color=#000000]b[/color][color=#000000])[/color][color=#000000];[/color]
  [color=#434f54]// Matrix operations[/color]
  [b][color=#d35400]Matrix[/color][/b] [color=#000000]B[/color] [color=#434f54]=[/color] [color=#000000]{[/color]
    [color=#000000]{[/color][color=#000000]1[/color][color=#434f54],[/color] [color=#000000]2[/color][color=#000000]}[/color][color=#434f54],[/color]
    [color=#000000]{[/color][color=#000000]3[/color][color=#434f54],[/color] [color=#000000]4[/color][color=#000000]}[/color][color=#434f54],[/color]
    [color=#000000]{[/color][color=#000000]5[/color][color=#434f54],[/color] [color=#000000]6[/color][color=#000000]}[/color][color=#434f54],[/color]
  [b][color=#d35400]Matrix[/color][/b] [color=#000000]C[/color] [color=#434f54]=[/color] [color=#000000]{[/color]
    [color=#000000]{[/color][color=#000000]10[/color][color=#434f54],[/color] [color=#000000]11[/color][color=#000000]}[/color][color=#434f54],[/color]
    [color=#000000]{[/color][color=#000000]12[/color][color=#434f54],[/color] [color=#000000]13[/color][color=#000000]}[/color][color=#434f54],[/color]
  [b][color=#d35400]Matrix[/color][/b] [color=#000000]D[/color] [color=#434f54]=[/color] [color=#434f54]-[/color][color=#d35400]transpose[/color][color=#000000]([/color][color=#000000]B[/color][color=#000000])[/color] [color=#434f54]*[/color] [color=#000000]B[/color] [color=#434f54]+[/color] [color=#000000]C[/color][color=#000000];[/color]
  [b][color=#d35400]Vector[/color][/b] [color=#000000]z[/color] [color=#434f54]=[/color] [color=#000000]{[/color][color=#000000]1[/color][color=#434f54],[/color] [color=#000000]2[/color][color=#434f54],[/color] [color=#000000]3[/color][color=#434f54],[/color] [color=#000000]4[/color][color=#000000]}[/color][color=#000000];[/color]
  [color=#000000]z[/color] [color=#434f54]*=[/color] [color=#000000]2[/color][color=#000000];[/color]
I'll probably be adding more algorithms soon, I have pivoted LU, Cholesky and eigenvalue algorithms lying around, but they need some cleanup and documentation first.
PieterP:
You guys are all so helpful! Thank you so much!
I'm really digging the syntax here; this is remarkably readable and very intuitive. I'm learning C at the moment (going through the K&R book) so I will probably have questions about your library over the next few days.
Btw, I read on the Arduino reference page that float and double are the same size... Is this only the case for the 8-bit boards or is it the case for the 32-bit Nano 33 BLE too?
sunmisola:
That only applies to 8-bit boards as far as I know. Easy enough to check though:
static_assert(sizeof(double) == 8, "double is not 64-bit");
static_assert(__ARM_FP & 0x04, "no 32-bit float FPU support");
static_assert(__ARM_FP & 0x08, "no 64-bit float FPU support");
The code also indicates that 32-bit hardware FPU support is available, but 64-bit is not, so it might be a good idea to use float instead of double.
