i'm using 32GB class 4 sandisk micro sd connected using XCSOURCE 1A 5V Micro USB TP4056, Arduino micro. I looked at the mapping here https://store.arduino.cc/usa/arduino-micro and connected gnd->gnd, vcc->3.3V, miso->miso, mosi->mosi, sck->sck, and cs->4 (digital pin). When I run the exampls I get
"Initializing SD card...initialization failed. Things to check:
- is a card inserted?
- is your wiring correct?
- did you change the chipSelect pin to match your shield or module?
serial output. Do you have an idea what's going on?
it saids on the Arduino guide that this is either wiring or card broken but the card is formatted FAT32 and works I checked.
