How to get cookies from a server using Arduino
I would like to obtain a CSRF cookie from a website on my arduino similarly to this issue: https://github.com/esp8266/Arduino/issues/1368
But I am not able to read any part of the header.
My relevant code:
String httpGETRequest(const char* serverName) {
  WiFiClientSecure client;
  client.setInsecure();
  HTTPClient http;
  const char * headerkeys[] = {"User-Agent","Set-Cookie","Cookie","Date","Content-Type","Connection"} ;
  size_t headerkeyssize = sizeof(headerkeys)/sizeof(char*);
  // serverName is the website I want to parse
  http.begin(client, serverName);
  http.collectHeaders(headerkeys,headerkeyssize);
  Serial.printf("Header count: %d\r\n", http.headers());
  for (int i=0; i < http.headers(); i++) {
    Serial.printf("%s = %s\r\n", http.headerName(i).c_str(), http.header(i).c_str());
  Serial.printf("Cookie: %s\r\n", http.header("Cookie").c_str());
  Serial.printf("Set-Cookie: %s\r\n", http.header("Set-Cookie").c_str());
  String payload = "{}";
  http.end();
  return payload;
However all fields are empty, nothing is returned. What am I doing wrong?
Can you post all of the code and what you see in the serial monitor?
This way we can reproduce your issue.
[edit] I do not see a request, so then I guess there are no response headers to collect.
So basically I would like to gather a CSRF token in order to be able to POST request.
I have codes in python, and there I only need an request session so I though it is similar here.
My full code:
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClient.h>
#include <Arduino_JSON.h>
const char* ssid = "my_ess_id";
const char* password = "my_password";
//Your Domain name with URL path or IP address with path
const char* serverName = "https://user.gravitybudapest.com";
// the following variables are unsigned longs because the time, measured in
// milliseconds, will quickly become a bigger number than can be stored in an int.
unsigned long lastTime = 0;
// Timer set to 10 minutes (600000)
//unsigned long timerDelay = 600000;
// Set timer to 5 seconds (5000)
unsigned long timerDelay = 5000;
String sensorReadings;
float sensorReadingsArr[3];
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  Serial.println("Timer set to 5 seconds (timerDelay variable), it will take 5 seconds before publishing the first reading.");
  // Send an HTTP POST request depending on timerDelay
  if ((millis() - lastTime) > timerDelay) {
    //Check WiFi connection status
    if(WiFi.status()== WL_CONNECTED){
      sensorReadings = httpGETRequest(serverName);
      Serial.println(sensorReadings);
      JSONVar myObject = JSON.parse(sensorReadings);
      // JSON.typeof(jsonVar) can be used to get the type of the var
      if (JSON.typeof(myObject) == "undefined") {
        Serial.println("Parsing input failed!");
        return;
      Serial.print("JSON object = ");
      Serial.println(myObject);
      // myObject.keys() can be used to get an array of all the keys in the object
      JSONVar keys = myObject.keys();
      for (int i = 0; i < keys.length(); i++) {
        JSONVar value = myObject[keys[i]];
        Serial.print(keys[i]);
        Serial.print(" = ");
        Serial.println(value);
        sensorReadingsArr[i] = double(value);
    else {
      Serial.println("WiFi Disconnected");
    lastTime = millis();
  HTTPClient http;
  String jsondata=("{\"nfc_id\": \"5365e544\"}");
  // Your IP address with path or Domain name with URL path
  //http.addHeader("Content-Type", "Content-Type: application/json");
//  int httpResponseCode = http.POST(jsondata); //Send the actual POST request
  int httpResponseCode = http.GET(); //Send the actual POST request
  if (httpResponseCode>0) {
    Serial.print("HTTP Response code: ");
    Serial.println(httpResponseCode);
    payload = http.getString();
  else {
    Serial.print("Error code: ");
  // Free resources
  http.end();
  return payload;
Thank you. Can you also share the output of the serial monitor?
I am sorry, this is my first time working on chips.
The output:
Connected to WiFi network with IP Address: 192.168.1.5
Header count: 6
User-Agent =
Set-Cookie =
Cookie =
Date =
Content-Type =
Connection =
Cookie:
Set-Cookie:
HTTP Response code: 200
Header count: 6
User-Agent =
Set-Cookie =
Cookie =
Date =
Content-Type =
Connection =
Cookie:
Set-Cookie:
As for the parsing input failed it is fine, I was able to parse JSON data from certain sources where only a GET request was required. I want to set up a POST request this time, but the server requires a CSRF token, which should be in the cookies of the header.
I am using a NodeMCU board if that matters!
I am not familiar with this library, but what happens when you change this:
to this:
(only moved one line).
Ohh man thanks a lot. now I get the correct headers! Sorry fo the noob question, I thought http.begin already sets up a session much like in Python!
Thanks a lot!
No problem. You can use the solution tickbox to indicate that the issue was solved to prevent other people spending time reading it.
