How to get CRC of sketch?
How to get CRC of downloaded sketch like ESP.getSketchMD5() function?
Of course i mean ESP8266 platform.
Choose a function that implements one of the many different CRC algorithms, and pass all the downloaded bytes to it. The function result will be the CRC value of those bytes.
I create this func:
String esp_crc_sketch(uint32_t address, uint32_t sketch_size) {
    CRC32 crc;
    uint32_t CRC_int;
    String CRC_string;
    char crcBuffer[9]; // Buffer to hold the formatted CRC string
    size_t len;
    uint32_t total;
    double start_time;
    const uint32_t timeout = 1000;
    uint8_t receive[256];
    DEBG_PRINT(__func__);
    //DEBG_PRINTF("Sketch size:%d\n", size);
    //address = 0x40100000;//Start of sketch
    DEBG_PRINTF("\nGet CRC of area from: %08X to %08X(%d bytes)\n", address, address + sketch_size, sketch_size);
    crc.setPolynome(0x04C11DB7);
    crc.setStartXOR(0xFFFFFFFF);
    crc.setEndXOR(0xFFFFFFFF);
    crc.setReverseIn(true);
    crc.setReverseOut(true);
    total = 0;
    start_time = millis();
    while (((millis() - start_time) < timeout) && (total < sketch_size)) {
        debug.printf("Read:%d/%d bytes\n", total, sketch_size);
        len = std::min(256u, (sketch_size - total));
        if (ESP.flashRead(address, &receive[0], len)) {
            crc.add(&receive[0], len);
            total += len;
            address += len;
        else {
            delay(20);
            debug.print("Fail to read esp flash\n");
    if (!(total > 0)) {
        debug.print("Zero size read!\n");
        return "NULL";
    if (!((millis() - start_time) < timeout)) {
        debug.print("Time out!\n");
        return "NULL";
    CRC_int = crc.getCRC();
    // Format the CRC string with leading zeros
    snprintf(crcBuffer, sizeof(crcBuffer), "%08x", CRC_int);
    CRC_string = String(crcBuffer);
    DEBG_PRINTF("CRC string:  %s\n", CRC_string);
    DEBG_PRINTF("CRC integer: %x\n", CRC_int);
    return CRC_string;
And call it:
esp_crc_sketch(0x40100000, ESP.getSketchSize());
But 'ESP.flashRead' func always returns false.
Looks like my IDE uses this scheme of memory maping:
/* Flash Split for 4M chips */
/* sketch @0x40200000 (~1019KB) (1044464B) */
/* empty  @0x402FEFF0 (~2052KB) (2101264B) */
/* spiffs @0x40500000 (~1000KB) (1024000B) */
/* eeprom @0x405FB000 (4KB) */
/* rfcal  @0x405FC000 (4KB) */
/* wifi   @0x405FD000 (12KB) */
MEMORY
  dport0_0_seg :                        org = 0x3FF00000, len = 0x10
  dram0_0_seg :                         org = 0x3FFE8000, len = 0x14000
  irom0_0_seg :                         org = 0x40201010, len = 0xfeff0
PROVIDE ( _FS_start = 0x40500000 );
PROVIDE ( _FS_end = 0x405FA000 );
PROVIDE ( _FS_page = 0x100 );
PROVIDE ( _FS_block = 0x2000 );
PROVIDE ( _EEPROM_start = 0x405fb000 );
/* The following symbols are DEPRECATED and will be REMOVED in a future release */
PROVIDE ( _SPIFFS_start = 0x40500000 );
PROVIDE ( _SPIFFS_end = 0x405FA000 );
PROVIDE ( _SPIFFS_page = 0x100 );
PROVIDE ( _SPIFFS_block = 0x2000 );
INCLUDE "local.eagle.app.v6.common.ld"
Every this points does not read. The function return false and i dont know how to put debug to it.
Excuse me. My function works correct.
Just start from zero address:
esp_crc_sketch(0x0U, ESP.getSketchSize());
Result the same as output binary. Thank for reading
