HOW TO GET DATA OUT OF LOOP
hi i wrote a code fo my esp8266 to serial communicate with at tiny 85 ,it will monitor switch state and publish accordingly. now i want to write a code where it wont publish but whenever the serial is available i want it to directly take it and digital write in void callback
//ItKindaWorks - Creative Commons 2016
//github.com/ItKindaWorks
//Requires PubSubClient found here: https://github.com/knolleary/pubsubclient
//ESP8266 Simple MQTT light controller
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
int LED3 = 12;
int LED4 = 14;
int LED2 = 13;
int LED1 = 15;
bool switch1;
bool switch2;
bool switch3;
bool switch4;
char data ;
// the number of the pushbutton pin
//EDIT THESE LINES TO MATCH YOUR SETUP
#define MQTT_SERVER "192.168.0.223"
const char* ssid = "TACHYON_HOME";
const char* password = "qwertyui";
//LED on ESP8266 GPIO2
char* lightTopic = "/test/light1";
char* lightTopic1 = "/test/light2";
char* lightTopic2 = "/test/light3";
char* lightTopic3 = "/test/light4";
WiFiClient wifiClient;
void callback(char* topic, byte* payload, unsigned int length);
PubSubClient client(MQTT_SERVER, 1883, callback, wifiClient);
  //initialize the light as an output and set to LOW (off)
  pinMode(LED3 , OUTPUT);
  pinMode(LED4 , OUTPUT);
  pinMode(LED1 , OUTPUT);
  pinMode(LED2 , OUTPUT);
    delay(100);
    // We start by connecting to a WiFi network
    Serial.print("Connecting to ");
    Serial.println(ssid);
    WiFi.begin(ssid, password);
        Serial.print(".");
    Serial.println("");
    Serial.println("WiFi connected.");
    Serial.println("IP address: ");
void loop(){
  //reconnect if connection is lost
  if (!client.connected() && WiFi.status() == 3) {reconnect();}
  //maintain MQTT connection
  client.loop();
  //MUST delay to allow ESP8266 WIFI functions to run
  delay(10);
   if (Serial.available()>0) /* If data available at serial port, enter if loop */
    data = Serial.read(); /* Read data present at serial port */
    /* Print string with \r\n */
    Serial.print(data); /* Print data received */
    if (data == 'q') {
      client.publish(lightTopic,"1");
else  if (data == 'w') {
      client.publish(lightTopic,"0");
 else  if (data == 'e') {
      client.publish(lightTopic1,"1");
    else if (data == 'r') {
      client.publish(lightTopic1,"0");
     else if (data == 't') {
      client.publish(lightTopic2,"1");
     else if  (data == 'y') {
      client.publish(lightTopic2,"0");
     else if (data == 'u') {
      client.publish(lightTopic3,"1");
     else if  (data == 'i') {
      client.publish(lightTopic3,"0");
  //convert topic to string to make it easier to work with
  String topicStr = topic;
  //Print out some debugging info
  Serial.println("Callback update.");
  Serial.print("Topic: ");
  Serial.println(topicStr);
 if(topicStr.equals(lightTopic)){
   if(payload[0] == '1'){
      digitalWrite(LED1 , HIGH);
    else if (payload[0] == '0'){
      digitalWrite(LED1 , LOW);
 if(topicStr.equals(lightTopic1)){
      digitalWrite(LED2 , HIGH);
      digitalWrite(LED2 , LOW);
 if(topicStr.equals(lightTopic2)){
      digitalWrite(LED3 , HIGH);
      digitalWrite(LED3 , LOW);
  if(topicStr.equals(lightTopic3)){
      digitalWrite(LED4 , HIGH);
      digitalWrite(LED4 , LOW);
void reconnect() {
  //attempt to connect to the wifi if connection is lost
  if(WiFi.status() != WL_CONNECTED){
    //debug printing
    //loop while we wait for connection
      Serial.print(".");
    //print out some more debug once connected
    Serial.println("");
    Serial.println("WiFi connected");
  //make sure we are connected to WIFI before attemping to reconnect to MQTT
  if(WiFi.status() == WL_CONNECTED){
  // Loop until we're reconnected to the MQTT server
    while (!client.connected()) {
      Serial.print("Attempting MQTT connection...");
      // Generate client name based on MAC address and last 8 bits of microsecond counter
      String clientName;
      clientName += "esp8266-";
      uint8_t mac[6];
      WiFi.macAddress(mac);
      clientName += macToStr(mac);
      //if connected, subscribe to the topic(s) we want to be notified about
      if (client.connect((char*) clientName.c_str())) {
        Serial.print("\tMTQQ Connected");
        client.subscribe(lightTopic);
        client.subscribe(lightTopic1);
        client.subscribe(lightTopic2);
        client.subscribe(lightTopic3);
      //otherwise print failed for debugging
      else{Serial.println("\tFailed."); abort();}
//generate unique name from MAC addr
String macToStr(const uint8_t* mac){
  String result;
  for (int i = 0; i < 6; ++i) {
    result += String(mac[i], 16);
    if (i < 5){
      result += ':';
  return result;
i want to write some thing like
if(topicStr.equals(lightTopic1)||Serial.available()>0){
   if(payload[0] == '1'|| data =q){
    else if (payload[0] == '0'|| data = w){
if (data == 'q') {
      callback(lightTopic,"1", 1);
PaulRB:
if (data == 'q') {
thank you paul but it will still switch things when its connected to mqtt only. i want it to be able to switch manually whenever there is something wrong with my lan
Why do you say that? Did you try it?
i dont have access to my modules, sorry but if the connection is lost then the while loop will run continuously, please correct me if im wrong. im a total noob ,and ill try it asap.
Before I try to help again, are there any other requirements you have not mentioned? I don’t want to waste time trying my best to help and then you say “oh, but I need X or Y or Z also”.
thanks for your patience paul. no i only want it to be able to switch things on and off from network and also directy from serial com update given by attiny even if it couldnt connect to wifi
OK, try this. It compiles but I can’t test it for you.
int LED3 = 12;
int LED4 = 14;
int LED2 = 13;
int LED1 = 15;
bool switch1;
bool switch2;
bool switch3;
bool switch4;
char data ;
  delay(100);
  reconnect();
  if (client.connected()) client.loop();
  delay(10);
  if (Serial.available() > 0) /* If data available at serial port, enter if loop */
    if (data == 'q') {
      if (client.connected()) client.publish(lightTopic, "1");
      else callback(lightTopic, (byte*) "1", 1);
      if (client.connected()) client.publish(lightTopic, "0");
      else callback(lightTopic, (byte*) "0", 1);
      if (client.connected()) client.publish(lightTopic1, "1");
      else callback(lightTopic1, (byte*) "1", 1);
      if (client.connected()) client.publish(lightTopic1, "0");
      else callback(lightTopic1, (byte*) "0", 1);
      if (client.connected()) client.publish(lightTopic2, "1");
      else callback(lightTopic2, (byte*) "1", 1);
      if (client.connected()) client.publish(lightTopic2, "0");
      else callback(lightTopic2, (byte*) "0", 1);
      if (client.connected()) client.publish(lightTopic3, "1");
      else callback(lightTopic3, (byte*) "1", 1);
      if (client.connected()) client.publish(lightTopic3, "0");
      else callback(lightTopic3, (byte*) "0", 1);
  if (topicStr.equals(lightTopic)) {
    if (payload[0] == '1') {
    else if (payload[0] == '0') {
  if (topicStr.equals(lightTopic1)) {
  if (topicStr.equals(lightTopic2)) {
  if (topicStr.equals(lightTopic3)) {
void reconnect() {
  static unsigned long lastConnectionCheck = 0;
  if (lastConnectionCheck == 0 || millis() - lastConnectionCheck > 120000) {
    lastConnectionCheck = millis();
    if (WiFi.status() != WL_CONNECTED) {
      //debug printing
      int retries = 0;
      while (WiFi.status() != WL_CONNECTED && retries++ < 50) {
        Serial.print(".");
      if (WiFi.status() == WL_CONNECTED) {
        Serial.println("");
      else {
        Serial.println("");
        Serial.println("WiFi connection failed.");
      int retries;
      while (!client.connected() && retries++ < 5) {
        String clientName;
        uint8_t mac[6];
      if (!client.connected()) {
        Serial.println("\tMQTT Connection Failed.");
String macToStr(const uint8_t* mac) {
  String result;
    if (i < 5) {
      result += ':';
  return result;
If/when it works, I don’t want you to simply accept it. I want you to understand every change I made, so ask any questions you need to.
thank you so much paul. im almost about to submit my project, i only didnt get the byte*
I've done your homework for you? Dang, should have seen that coming!
The (byte*) doesn't really do anything. It just stops the C compiler from complaining. The client.publish() function expects a C-string as the payload, but the callback() function expects it to be a pointer to an array of bytes. In reality there is no real difference between those 2 things. So the (byte*) tells the compiler to "cast" or pretend that the C-string is an array of bytes (which it is anyway) and that stops the compiler from complaining.
Note that a C-string is not the same thing as a String, even though they appear to be.
